Click here to Donate
Adrian Chirila
  • Content Count
    4
Everything posted by Adrian Chirila
  1. ok.I understand. I will find a smoke machine. And with other reader gives me P2187 and P2189 system too lean.I hope is from the air leak.Thank you
  2. the P2281 it is possible to be from that aluminium pipe from the bottom intercooler?
  3. I will change the purge valve including that pipe.and I will look on all the pipes from MAFs to throttle body.I don't know where to find a pressure test here in Uk. Thank you
  4. Hi all, where to look? P0441 - fuel tank ventilation system(above upper limit value) P2281 - Throttle Plate(below lower limit exceeded) After I refuel, sometimes has a hesitation start. When is cold the start is not normal(rpm is going to 1000 max not 1400-1500 like when is hot). Somentimes when I kickdown in 2 gear has a hesitation. After 30-40min driving the PRND all are light up and the gear changing is not so smooth. I cleaned the MAF sensors, changed the intercoolers seals( a aluminium pipe has a crack, waiting the order) For P0
