Powerdna
Everything posted by Powerdna
  1. Is this the same as an oil sender? I am doing several searches found this reference. Thanks Again. Andrew
  2. Even better I was not looking forward to removeing the console. Do you have a link with the replacement directions? Andrew
  3. Does anyone have the part number for this micro switch? 2000 Boxster S Thanks Andrew
  4. I have a MY 2000 Boxster S. I took it for a short drive and noticed that there was no oil that is registering on the Engine Oil Level Guage. I checked the oil manually using the dip stick and all is well, so i continued my drive home. Does anyone have any suggestions on what to check, loose connection, etc.? I did add a few ounces to bring the oil level up to max on the physical dip stick but still do not receive an oil level on the display screen. Thanks in advance for any advice. Andrew
  5. Update to Post DIY: V1 Switched Power Hardwire Installation, V1 Switched Power Hardwire Installation BY: 1080iAddict http://www.renntech.org/forums/index.php?s...l=valentine+one Here are the changes that I found on my 996 (without auto-dimming mirror option) from the 997 in the post listed above. Postive Lead is Red/Black Stripe Negative Lead is Brown This install is non-switched, so you will have to turn off your device manually. Enjoy, Andrew
  6. DIY: V1 Install on 996 Without Auto-Dimming Mirror Update to Post DIY: V1 Switched Power Hardwire Installation, V1 Switched Power Hardwire Installation BY: 1080iAddict http://www.renntech.org/forums/index.php?s...l=valentine+one Here are the changes that I found on my 996 (without auto-dimming mirror option) from the 997 in the post listed above. Postive Lead is Red/Black Stripe Negative Lead is Brown This install is non-switched, so you will have to turn off your device manually. Enjoy, Andrew Author Powerdna Category Carrera (996) - Accessories Submitted 06/17/2008 12:52 PM
  7. Thank you all for your reply's. Is traction control standard on the 03 model I did not see it listed on the website. Thanks again for your input. Andrew
  8. Does anyone have a model year comparison between 02 and 03 for the Boxster and Boxster S? Opinion Wanted: I am looking at a 02 Boxster S and an 03 Boxster. They are the roughly the same money, and mileage. The 03 appears to have more options, Bose Radio upgrades, seat upgrades, and trim. I am looking for a reliable daily driver to add to my garage. What would you choose and why? Thank you for your comments.
  9. Please clarify, your physical key will not unlock the car door? I have had a similar issue where my key fob will not unlock any doors after a few days of not being used. I have always unlocked the driver’s door physically, (alarm may sound) click the unlock on the fob then all is well. Andrew
  10. Thank you all for the quick responses. I was planning on a 03 or 04 986 primarily for price, but if i found the correct 05 I would consider that too. I usually look for certified cars but I am not sure that will be a requirement this time around. Thanks for all the responses.
  11. 986 Questions. How reliable is the 986 series? I am planning on using it for a daily driver including winters (Wisconsin), about 7000 miles a year. With a full set of snow tires is it an acceptable, reliable vehicle? I have no doubts that it isn’t reliable, I am just looking for input, examples or suggestions if anyone has any. I would consider a Cayenne, but garage space is extremely limited, and my snow/ice winter driving will be very limited. Anything I should be on the lookout for prior to purchase specifically relating to the 986? What model year did Porsche start use of a glass rear window? Does the rear window contain the defrost option? Thanks in advance for any suggestions, comments. Andrew
  12. Could anyone assist with a PPG paint code for OEM Porsche wheels? I would like to paint my wheel bolts as they are starting to rust. Other suggestions appreciated too. Thanks in Advance
  13. I would like to acquire as much data as possible from the existing ODBII connection. I would like to log it as well as have real time displays in the car. Does anyone have any suggestions. Thanks in advance. Andrew 03’ 996 C2
