Seaquester
Everything posted by Seaquester
  1. FIXED! Sort of. Just in case someone else might run into this problem...The spring contact in the right rear stoplight assembly broke and shorted to the running lights. I pulled the broken contact out and everything is working again. Now I just need to find the socket for the bulb and all will be as it should. (Right now I'm running down one running light) Thanks
  2. Just a little update. The brake lights are coming on with the right side parking lamps so I suppose it is looking more like a short... Oh -- and it's 5 degrees in wyoming - I knew there was a reason I live in southern Nevada!
  3. The chrging system has not been specifically checked but the voltmeter indicates just less than 14 on start up. I have read allot about the ignition switch going bad. I may change it out just to limit the possibilites. A short is definately a possibility. I suppose I can check for continuity between the running and stop lights with the lights out to verify that. I was kind of hoping the brake lights ran through the headlamp switch. The problem seemed to start when I stopped for a minute in Beautiful Beaver Utah. Stopped with no problem - 5 minutes later I turn on the headlight switch and the PSM/ABS annunciater lights come on and the MFD is directing me to go to the shop. When I shut down the ABS/.PSM system is fine until the headlights are turned on again. Thanks!
  4. The strangest thing is happening and I have searched but can't seem to find a post with the same symptoms. I have a 2002 C4S. The cruise has stopped working but more importantly the PSM and ABS fails when the headlights (or even the parking lights) are switched on. The brake lights work from the brake pedal when the headlights are off but when the headlights are turned on the brake lights come on (including the center light) and stay on. I'm thinking headlight switch but that doesn't explain why the cruise control doesn't work when the lights are off. When the headlights are off ABS and PSM are fine. Thanks for any help you can offer. Bill
