kjagrant
Everything posted by kjagrant
  1. Thanks Loren. Its hard not to get caught up in the IMS hysteria. This car has run flawlessly for the 3.5 years that I've had it. This is the first real problem that I've encountered. Will check sensor.
  2. My 996 is running rough. It idles rough and stumbles when the throttle is applied. It threw the following codes: P0341 Camshaft Position Sensor 1 - Signal Implausible, Short to Ground, Short to B+ P1316 Misfire, Cylinder 4, Emission Relevant P1317 Misfire, Cylinder 5, Emission Relevant P1318 Misfire, Cylinder 6, Emission Relevant P1319 Misfire, Emission Relevant Would a bad camshaft position sensor cause the rough running? Would it cause misfires on the other bank of cylinders? Also, can the bank 1 camshaft position sensor be replaced with the engine in the car? It looks hard to get to. Thanks
