PorschePower06
Everything posted by PorschePower06
  1. It is the outside piece that color coded and is a heavy metal - if it were on the driver handle it would have the key hole in it. I will try to get a pic oday.
  2. The back part of the rear passenger door handle on my 06 Cayenne pops out when the handle is opened. I can hit it hard to push it back in but it pops out all the time. Has anyone else experienced this? Do you know if a replacement / fix would be covered under warranty? Thanks in advance... -RL
  3. My service light just came on my 06 Cayenne S - I have 20+k on it. I looked at the Service I in the manual and it is all a waste of $$ spent at the dealer ( no real work done other than oil change ). So I am looking to get a OBD II reader / code reset tool - any opinions on who makes the best? http://www.durametric.com/ Actron CP9135 AutoScanner Diagnostic Code Scanner with On Screen Definitions for OBDII (Post-1996) Vehicles http://www.amazon.com/gp/product/B00009RAX...&n=15684181 Others? Thanks
  4. Great - thank you. From that graphic what I started to drain was not the front differential fluid. Any idea what is in the reservoir in the attached image and where to check the level and fill?
  5. How do you check the level of the front differential fluid and where do you fill it from? - I accidently drained some out when changing the oil for the first time.... Thanks in advance
  6. Ok - how do you check the level of the front differential fluid and where do you fill it from? Thank you!
  7. HELPPPP! I did the same as the below - What is the other oil? It did have a green hue with metallic looking pieces and smelled. Does anyone know what that is and how to replace it???
