joshmoney
Everything posted by joshmoney
  1. The rear sensor is what went out in mine. The way I fixed it is that I just disconnected the arm from the suspension. ha. sensor is like 100.00 bucks so I'll just deal with no movement up and down for awhile.
  2. mine does the same thing. kind of embarrassing too. driving a nice car like this, and it sounds like something is falling apart. But, I've learned to just turn the radio up
  3. A new controller may be the ticket to fix your issue. But, you might want to check the servos first. Take the center part of the dash apart, plug in your controller and cycle through heat and ac. You should be able to see the flaps move. If one doesn't move, swap the plug with a different one to see if you have a faulty servo. I bought my controller from sunset porsche. they had the best deal on the net I could find. I have to use mail order because the nearest porsche dealer is about 4 hours away from me.
  4. I had to add two cans of refrigerant to make it work right. Made the ac work correctly. Yours sounds like a different problem.
  5. No pics. Just remember to take your time. Trim around the stereo is just pressed in and it pops out fairly easily. If I remember correctly, if you just want to replace the ac controller, that is the only part you have to take off. press in the metal clip things on both sides of it ( they are shiny compared to everything else)and it will slide out. Plugs are on the back of it.
  6. I just thought of something else. I had my stereo unplugged for like 2 weeks for waiting on that controller to arrive, now it is displaying the text about the songs that are on the radio. That never worked before. I guess it reset itself. Yet another bonus for this part replacement. :P
  7. the part was a little over 200.00 through sunset. Give them your vin because there is like 15 different types of controllers for this car. I determined it was that part that was screwed up because I tested the actuators on different plugs and it wasn't making them move on some of the plugs. I replaced it myself yesterday. the hardest part of replacing the unit was getting it out of the dash. you have to get 2 flat head screw drivers and press against the metal clips holding it in there. It slides out like a stereo. My new part has a silver fascia, instead of black, so I think it looks better too. I no longer have the clicking noises inside the dash. I believe that was caused by the controller sending intermittent signals to the actuators for no reason. Also, the fan immediately comes on now, without the 4 or 5 minute pause like you and I were having. I'm hesitant to though the old part in the trash as of yet. Maybe I'll take it apart or something to see how it works (or how it doesn't work). But, the temp on the passenger side is not as cold as the driver's side (which is much improved, though). I believe I may have a faulty temp sensor on the passenger side. Those shouldn't be too hard to replace. The one I think is messed up is behind the glove box. Not an expensive part, either. only like 15.00 bucks, so I'll try that. I'd test the old one, but I have no idea how to test a temp sensor.
  8. My 04 S has about the same mileage and it has been doing the same thing. But, most recently, it stopped blowing cold air on the passenger side. I believe my problem is the a/c controller (main thing in the dash with the ac switches). I ordered a new one and I'm waiting for it to come in because it was special order.
  9. I've got my entire dash tore apart trying to figure out what is causing the driver side to blow cold air, while the passenger side is blowing air like its comeing directly from outside. I thought it was a solenoid went out, but after testing 4 of them, I'm getting frustrated. Anyone have any ideas? Could it be the air controller going out on me? I'm doing it myself because I'm out of warranty on my 04 s. I only have 2 zone climate control
