- Paint Codes
marilynmichael
Contributing Members-
26 -
Last visited
Exterior Paint Colors
Classifieds
Everything posted by marilynmichael
I took my 2002 Targa to Porsche to figure out why the car would not lock. After about $5K of various and sundries that I cannot remember (I want to forget) -- the car locks. But, at the end, the mechanic told me that they something was wrong with the memory seat control unit and that to get the car to lock, they had to unhook it. Now--I know all of these things seem to be tied together in a Porsche--so, at that point, the guy just put the seat in a middle position and I left with $5K less in my pocket, a car that could now lock, but a driver's seat that cannot be adjusted. He said something about how it could be plugged in temporarily to move it, but then the car wouldn't lock, etc. Argh! So---they quote me around $1500 to replace the memory seat control unit. Is this something I can buy and replace fairly simply myself? My backside is getting pretty sore. Thank you Michael
I hooked up the battery and charged it with a trickle charger. Charged to full over night. Shows 14 volts on the gauge. Guess that's about right. Problem still exists. I noted that my seat belt, when fully extended, seems to be a bit damp--both of them. Maybe they are just cold -- but they kind of feel damp, so I thought--ok, let's check the drains. Front ones near the battery were fine. Nothing clogging. Cleaned it out a bit and blew compressed air down. Pour water through them and water came out below fine. Checked the front drains of the car with the Targa roof retracted. They were clear as well. Blew air and poured water through. I could not see the entrances (holes) to the rear drains, so I semi-gave up, hoping the problem would go away. Alas, and not surprising, the problem still exists. The interior lock button sometimes 'works' and sometimes does not. The car 'beeps' when locking sometimes and sometimes not. The driver's seat moves forward and back sometimes and sometimes does not respond to the switch. Today, was warm and sunny so I went out on the hunt for the rear drain 'entries'. I could not find them. I did find the kind of pop in, pop out funnels from the targa roof to the side roof drains. They were properly placed. While doing that, I noted that the 'mesh' along the driver's side of the rear roof (rear roof opened on the Targa) was very damp. The passenger side was not. This semi-confirmed in my head that the 'rear roof drain' on the driver's side must be clogged. I poured some water from into the open sliding roof. Water came out behind the rear wheel. But, maybe it drains slowly--dunno. So--I pulled the rear wheel based on what I had read on some posts to see if the exit point might be somewhat clogged. I pulled the plastic covering from the wheel well hoping to see the exit point-but nothing there. I poured water again from the open roof and noted water exiting kind of from the rear portion of the wheel well--but not from some clear exit point but kind of from a metal seem. I cannot find the entry hole for the rear roof drain and I cannot find the exit hole for the rear roof drain. I've looked thought the diagrams, etc and I cannot find it. At this point, i'm about to take the poor thing into Porsche and throw my hands and wallet in the air. I'm afraid the electronics are a bit compromised (I checked under the seats and I didn't really find it damp and certainly not damp--but the car was covered (Porsche cover) and out in some heavy rain for two weeks a while back) by moisture/condensation. And--the 'mesh' on the left of the rear roof was defintely damp/wet but I cannot find where the drains are. To the shop or another idea? Thanks for your help
2002 Targa Has been a bit humid inside the car, but not wet. Now, when I close the driver's door, the side window, opens slightly and then closes back--and repeats. A lot. I open the door and sometimes this stops the behavoir and sometime is does not. Repeat until it stops. When I go to lock the car, I get a horn beep--which as I understand means something is not closed properly. I open and close the doors and then it goes away--but I swear, the doors are closed properly Today---pouring rain. I go to turn on the headlights--turn the knob. Will only physically turn to the parking lights--not all the way to the right for the full headlights. I pulled out the switch to put on the fog lights and they came on fine. I tried to turn it to full lights while pulled out, but it wouldn't budge. Something appears to be funky with the electrics. Clues? Thanks for you help!
I have a 2002 Targa living in Florida. I've had no problems until it turned colder. Now I have pretty heavy condensation on the windows every morning and any chilly afternoon. I've read through the forum and checked all of the drains. They all seem to be clear. I've also felt around and checked for moisture on the carpet etc. I don't seem to feel anything in particular. It might be a little wet on the front right passenger carpet--up against the wall---but just slightly perhaps. And, I've gone over all of the rubber seals on the doors, roof, lid (Targa) etc. I do see a bit of a tear on the read lid. I stored the car under a car cover for 2 weeks a week ago. I came back, opened it up and it was really quite damp in the car. The guages had condensation even the manuals inside the glove box. I suppose this was simply because I have something leaking 'under' the car cover and the moisture built up quite a bit. It did rain a lot (but again--under a cover--not water proof I guess (Porsche brand). Bottom line is that the only thing that 'seems' wrong is a rip in the seal of the Targa rear lid. It's not all that bad--but perhaps it's bad enough. But, I don't want to go replacing that if it is not really the problem. Any thoughts appreciated. Thank you
I have a 2004 Cayenne S. Grey interior. A few things don't function correctly and I'd like to fix them up if it's not too hard and I can find the parts. I'd appreciate advice on how hard it is to fix these and where to go to find parts. Center console trim. This is the trim panel that basically covers the center console--goes around the shift trim piece, cup holders etc. Mine is pretty scratched up. Hard to replace? I have found lots of 'trim kits' but I like the original grey/metal look in the car and only need this piece. Any advice where to find? Latch for center console 'box'. I found the latch at Suncoast. Is this difficult to replace? Sunglass holder. The holder is there and is fine--it's the latch. I seem to be missing half the latch. I put some coins in there to keep it closed now--which keeps it shut, but I'd like to put the proper latch in to actually use it again. Can't seem to find this latch. Easy to replace? Front cigarette lighter does not function. No power coming from it. Not really sure what is wrong on this one. AC buttons. All of this works fine--but the button are scraped up. Can you buy just the buttons somewhere? Hard to replace them? Metal 'Cayenne S' trim 'entry strips/lights'. These are the metal strips that you go over coming into the car. They work fine--but one front and one rear just don't stay attached anymore. I've tried all kinds of glues. I live in Florida and it seems the extreme heat is just not helping. Got an idea for some great adhesive to use? Thanks for you help.
I recently bought a 2002 Targa. When I turn on the parking lights, the side markers come on and the rear lights come on--but no lights are on in the front of the car. Is this normal? When I lock and unlock the car, the 'yellow lights' in the bottom half of the headlights flash. Shouldn't those light when the parking lights are on? Thanks for your help
I have a 2004 Cayenne S. Almost 80K miles. Been great. Basically no problems. The other day, I'm driving along and the sun roof starts opening and closing on its own (popping up). It was moving like I was pushing the button. I pushed the button and it seemed to kind of reset and I haven't seen that problem since. The past couple of days, I go to turn the ignition and it flashes the 'battery' warning (red battery light) but starts. I noted that the clock was back to 12--lost its time. But, it doesn't seem to have low battery power. It starts and the lights are strong, etc. But it was like the electrical system had reset or something. This evening, I come out of a store. Turn the key and it won't start. Like the battery is 'almost' dead. Tried it twice and same thing. Then I tried one more time and it started like 'normal'--plenty of battery power. Any help appreciated. Thank you Michael
I have a 2004 Cayenne S. Moved to Florida a few months ago and everyone of the aluminum door sills (the lighted 'Cayenne' things) has come lose. They are held to the car using some plastic holders which attach--with glue?--to the aluminum sills. The glue has melted or something. I have not been able to find a glue that will re-attach (and hold) the plastic 'things' back to the aluminum. Any help with this would be most appreciated! Michael
So, need to remove my headlamps. Went to the trunk, lifted the inside lid and see this nice little set of tools in a styrofoam holder. Unfortunately, it seems to have some missing tools, including the wrench for removing the headlamps. I read that this is a hex wrench of sorts. Is it best to go to Porsche and buy a new one or can I just purchase some size of female hex wrench for this? Size? Thank you Michael
I have a 2004 Cayenne S. I purchased the car used from a dealer about a year and a half ago. I drove it off the lot and noticed 'gerbils' in the dashboard. Drove straight back to the dealer. Car was gone for a few days and came back 'fixed'. The 'gerbils' have returned along with 'wind rushing' and 'creaking' noises. These are essentially in the dash, but also, now, down by the drivers feet area. It seems that this happens when the climate control system is heating and not when in AC. Not 100% sure on that. So, I searched a saw a few things out there. Basically, read that 'some say this is expensive to fix' and 'servo motors'. I have heard I need to remove the entire dash from the car. Questions: 1. What is not working correctly? 2. Do it yourself or just too complex? 3. If I take it to a shop, how much $$$ to fix? Thank you Michael
OK...latest little thing on my Cayenne S 04. I have a problem opening the center console--the 'box' just behind the cup holders. I can open the bottom portion just fine, but when I push on the upper button to open the top portion--won't budge. Seems to have a lot of slack. I have moved it around, pushed the button hard/soft. Pried it a bit :o Nothing opens it. Any help appreciated! Otherwise, seem to have a similar problem opening the glove box. Sometimes it opens; sometimes it doesn't. Do I just need to replace something or tighten something? Thanks Michael
I have a friend that has totaled his Cayenne :o I was thinking of pulling his Xenon 'system' and replacing my standard headlights on a 2004 Cayenne S(his is same S and year, but with Xenons). Can anyone tell me what parts I need to take to make this work? My thoughts are: - lamps - bulbs - transformer/relay 'thingy' - wiring harness??? Anything else?? Does the transformer/relay 'pack' have the control system in it?? Thank you!
Hi Bill, I took it to the mechanic. They replaced the drive shaft. And, from what I understood--the CV joint as well. Problem was---that it 'pretty much' fixed it, but it still happened a bit. Less...but still some. They drove it around with me after I took it back. They noted that my tires were pretty worn. They said the noise seems to be coming from the transfer case. And, they suggested that I change the tires to new ones. It all sounded a bit strage to me, but I know these guys pretty well. Anyhow, put new tires on about 2 hours ago and the noise seems to be gone....at least so far. They said that the transfer case 'stuff' is really sensitive to the tires having equal wear, etc. Michael
I have a 2004 Cayenne S. 46K miles. When I start from a stop with a slight amount of acceleration, I get a 'thump-thump-thump' -- seems to be coming from the right rear. This doesn't happen all the time. Just some of the time. Sounds very mechanical I took it to the shop. They replaced the rear drive shaft and CV joint. Well, although it is less frequent...it still occurs. So, I took it back to the same shop the next day. Had the mechanic drive around with me and he definitely heard it. They took it back in and said that it is coming from the transfer case. Said it really doesn't it when the gearing is put in low ratio. Now...my tires are pretty worn and I had bought them with porsche OEM wheels used (went from 18" to 20"). The mechanic suggested that I change all of the tires and see what happens. Says that the transfer case is extremely sensitive to uneveness in the tires, etc. I'll get new tires tomorrow, but that all seems a bit fishy to me. I read about a recall that was made on 2004 about the transfer case cracking or something. I don't know. All a bit strange. I bought the car used about 9 months ago with 41K miles. I bought an after market powertrain warranty (whew...) which covered the replacement of the drive shaft/CV joint and I guess would cover repairs to the transfer case too. Any thoughts?
I have a 2004 Cayenne S with 45K miles. A few days ago, I noticed a thumping/clicking noise coming from the right rear. I sounds and kind of feels like I have a flat tire--but not so simple. It only happens at slow speeds (very slow) and I believe mostly when making slow turns. I was thinking this is a bad CV joint, but I called my mechanic this morning and he was saying it sounds like the drive shaft--saying he has replaced so many of them on Cayennes. Any ideas? Other symptoms/problems? Worried about costs....Guess I should not put this off??? Thank you very much for the help. Michael
OK...so, my nice used 2004 Cayenne S...sitting in the hot sun for the first time...the rear view mirror came off the windshield and is dangling. I thought this was a simple fix and went down to the local auto parts store and bought rear view mirror glue. Used the cleaning gel, etc. Stuck it on, let it sit a day in the shade. All seemed go. Today, back in the parking lot sitting in the hot sun. Dangling mirror...arghdslfkjhdsflksdfhgdflgkhdglfdskhjf!!!!! Do I need some kind of special adhesive for 'porsche' windshields or something? Thank you Michael
I have a 2004 Cayenne S with factory installed towing. I have been trying to install a Sonar Step wireless back up system on the vehicle, but it fails. I plug the same one in on a friend's Toyota 4Runner and it works perfectly fine. We measured the voltage between the ground (bottom left pin) and the reverse (center) on my electrics. Whether in reverse or not, it puts out a pulsating 18 to 24v. On my buddies Toyota the voltage is 0 when not in reverse and 24 when in reverse. Any ideas ?
[Was this a kit that you put together using the parts specified in the earlier postings, something you bought somewhere, or something installed for you? Thanks quote name=SOH' date='Mar 18 2009, 01:20 PM' post='135154] Hi there! I know I may be light years behind you in answering, but anyway, somebody else might find this useful. My Cayenne S (MY2004) has a retrofitted Bi-Xenon kit instead of the original halogen, fully working. Inside of each housing are two units for the high and low beam respectively. Every work was done inside the housing, that is, you can take the housing out of the car and do all the wiring work on your kitchen table =) The back covers fit back on so no humidity is able to slip in, very clean work. Hope this becomes useful for someone.
I have a 2004 Cayenne with factory installed towing package. It did not have a towing 'receptacle' so I bought one that I found on the web that goes on a Toureg. I installed that fine, removing the cover plate, and putting this in. It now has a nice 7 pin 'plug' with covering flap. I also purchased a Dophin Wireless Sensing System--SonarStep http://www.mechanics-warehouse.com/dolphin-step.htm and hooked it up. Him..not working. So, I called tech support at the manufacturer and checked fuses, etc.. And, I put a voltmeter on the 'receptacle' and I get 12v on some of the connections and some kind of alternativing 6v power on some (when the car is in reverse). The guy asked me to find out what is the power diagram for the Cayenne. Basically, the thing is not getting power from the receptacle I put in, but I get power on a couple of the clips in the receptacle when I put it in reverse. Am I supposed to get power on all? I guess it depends on if the turn signal, etc is on...things like that. So...: question 1: has anyone successfully hooked up a 'SonarStep' to their Cayenne and how did they get it to work? question 2: can anyone give me a diagram of the 7 pin connector? I see it is a 7 pin A connector from the Cayenne owners manual...but I am lost beyond that. Thank you Michael
Can't open rear trunk
marilynmichael replied to marilynmichael's topic in 986 Series (Boxster, Boxster S)
Well, I read the users manual and didn't find anything about an emergency cable location. Only about jumping from the fuse box. But that is not the problem. I have battery and plenty of it. Everything works fine except the rear lid won't open. I did hunt around and saw something about finding the emergency cable release by taking off the rear tire, and a few other things. When I flip the switch next to the drivers seat or use the key fob, everything 'sounds' like it works fine. You go back and the lid is not open and it is shut like a drum. It does not seems like a broken cable(s) -- 2! to me. I guess I'll try to pry it 'gently' while someone pops the switch/fob as suggested, but it really seems 'locked'. What I was thinking is that since this all started with the key fob battery running out and changing that--that something needed to be 'reprogrammed' or 'reset' on the fob, alarm system, whatever. I hunted around and someone said something about putting the key in and pressing the fob open button for 10 seconds or something...but it wasn't clear. Any help on something else beside physical force (which I'll try in the morning..) is greatly appreciated. Michael -
OK. I have tried: - searching around on the site for more details but I can't find anything about this. Lots of things about front trunks not opening, doors, etc. But nothing about the rear trunk not opening and still making the 'mechanical' sound. What you suggest--the latch being broken--sounds reasonable, but I mean--nothing was done except the battery running out in the remote and changing it. It is hard for me to imagine that the cable would be broken. - I have also crawled all around the wheel wells (both left and right) under the rear bumper..etc to no avail. I cannot find the emergency cable. Is it hidden 'under' a flap or something? I have push, proded and pulled anything I can find. Thanks for your help.
