valcax
Everything posted by valcax
  1. and the other numbers "363.303.09"? not the same... :huh:
  2. I have got to pull out the cap with corkscrew, I have seen part number behind but it´s not 000 044 600 12 Part number is: 993.361.303.09 Why part number is not the same? Regards. <{POST_SNAPBACK}>
  3. I have got to pull out the cap with corkscrew, I have seen part number behind but it is not that, Part number is: 993.361.303.09 Why part number is not the same? Regards.
  4. how is procedure to put cap on again? only pushing?
  5. I just lost a wheel cap also. LVDell and Loren sent me a couple of sites that have a good selection of replacement caps. I'm guessing they're cheaper than a dealer . . . Wheel Enhancement definitely has a match for the one you need. The links: www.tweeks.com Wheel Enhancement I hope this helps. - Pete <{POST_SNAPBACK}> thanks for that sites, they are good! Which is what I am looking for....... second one? Which cap is installed in new Porsche models? Black on silver, color, or what? Regards.
  6. thanks! I am waiting.....
  7. how do you introduce it?
  8. any tutorial to change it ? which kind of tool is? Regards.
  9. Can you explain how to do, any picture?
  10. Can I get pcm1 16bits cd reader buying? part number? I am thinking installing myself..... is very difficult? Note: until 2002 pcm1 disks are supported by navtech, 2004 disks are supported only by Porsche (porsche tequipment) Regards.
  11. Thanks!! Is very diffcult to change it? how is the procedure? or I have to go to my dealer??
  12. Model year 1999, Boxster, manual transmission, 18" Sport Classic II Rad. Part number??? Regards.
  13. I CAN assure you pcm1 16 bits 2004 cds exists as Porsche tequipment. look here http://cgi.ebay.es/ws/eBayISAPI.dll?ViewIt...ssPageName=WD2V Then opel cd navs dont work in pcm1 8 bits? necessary 16 bits? Regards.
  14. there is a thing I dont understand, Pcm1 16 bits is sold in Spain with 8 disks 2004 , not 2002, and you say introducing 2002 disks is necessary to update? I guess Porsche updates software with proper disks and they give updated disks 2004.
  15. THATS very interesting!!!! Then I can use opel cd navs, updated??? how I can get that opel cd navs???. Regards.
  16. I guess to update pcm1 8 bits to 16 bits it is necessary only changing cd reader, not all system. Anyone can confirm? Loren? :) PRICE?? Regards.
  17. I have emailed to NAVTEQ about updated cds.... Its interesting what they have told me......... " we dont have responsability about updates, we make a data base updated for many cars maker, then they are who program the cd matrix with the GPS company (siemens) buying our database." Porsche has all responsability!!!! what do you think we can do?? emailing porsche???? Best Regards.
  18. No, now navteq and porsche dont couple !!!! How I can know if my pcm1 system has 1999.1, 2000.1 or 2001.1 map version??????
  19. WHERE I CAN CALL TO GET PCM1 NAVIGATION DISK OF SPAIN??? UPDATED!! REGARDS.
  20. OK!, in top coolant tank says ............."water!!!!!!" ONLY WITH WATER?? :huh:
  21. The other day temperature light began turned on and off, I did not know what was the problem, but I was quiet because temperature indicator was in the middle. When I arrived I tried to verify coolant level and I filled in with antifreezing-coolant liquid (-13ºC). Then temperature light turned off. Question: Am I right or wrong to fill with this kind of liquid? or Porsche recommends any other more specific? Porsche Boxster 2.5 5/7/99 Manual trasmission. Regards,
  22. thanks for replies, two questions, a sport suspension has the same spring than standar?? the only difference is compensation spacers to match proper ride height (-10mm)??, for example in this case 2.0 and 3.0.... I am right?? Regards
  23. can you explain meaning 3.0 and 4.0 compensation spacer? and 5 speed? Regards.
  24. Here you have results: Porsche Boxster 5/7/99 Manual Transmission.- Code colors:
  25. ... is equipped with sport suspension??? You´ll see, I have verified all option codes in my boxster but there is no "M030" option code. I guess car is equipped because the old owner installed it, but I am not sure, ................ is there any way to know it? Regards.
