voodoocat
Everything posted by voodoocat
  1. I get puddles in my garage every day, and today it was 60f day. Coolant is right level, have not lost coolant, and had coolant pipe replaced previously (2004). I think it's condensation. The spot is right front area, right below front passengers foot will be. Smelling it will be the best way to tell. Try driving in ECON mode (no A/C) and see if it happens.
  2. Is this like steering wheel pulsating when turn the wheel all the way? It felt like steering pump was going bad.
  3. Make sure to use triple square not ordinary torx, and go slow. reg torx will strip the aluminum bolt. it's torqued very tight.
  4. Every time I wash the car I get intermittent problem. As I back out it's ok, but immediately sometimes, sometimes when front is being sensed, it goes red. With durametric it says front inside sensor fail, signal ground or open - or something like that. In Summer, wash car, it fails and after a week, back to normal. Then it failed for long time. I thought it was loose connection so pulled f bumper, wd40 the connectors, but no difference. I bought replacement sensor but have not got around to paint them. Then (~2 months later) it's working again. Wash car, error. put vacuum on the suspect sensor to suck out moisture, working again. It's driving me crazy. I don't want to undergo 'remove bumper replace 1 sensor, reassemble - failure - remove bumper again...' routine. (2004 TT)
  5. The Autozone/Duralast H8-DLG fits 100% as the original Varta. $133.99. It's the heaviest battery I've seen (50LB) Don't forget to connect vent tube (L vent hole), and re-use the plug (R vent hole) You must use 10mm triple square bit for driver seat bolt removal, do not use 10mm torx. It will strip the aluminum screw. It's tightened at very high torque due to threadlocker. Go slow. My Varta appears to have full charge (built-in hygrometer shows green) but no more capacity. 20 minutes of stereo -> wouldn't crank. (but will crank if I don't use accessories). Autozone has 3 year replacement / 8 year pro-rated warranty so I suggest to just replace it; it's only $134.
  6. This just happened to me last week. Issue 1 When I got the (used) Cayenne, the original owner swapped the PCM with CDR23 from somewhere. (I bet he ebay'd the PCM) I'm told that the CDR23 stores VIN, so it didn't match car (console/dashboard computer) VIN. The tech changed the console VIN to CDR23's and stereo worked. I'm told to make sure the tech won't change console VIN back to the car's VIN on subsequent services, or stereo will stop working again. Note, they forgot to set CDChanger bit on. Issue 2 Installed Dension gateway, found out CDC bit is not set, so back to tech. Can't get to CDR23, apparently Dension was blocking access. I think they tried the bypass switch on/off, but can't get PIWIS to accessing CDR23. Took out Dension and tried again, CDC bit was set right away (matter of few minutes). So I suggest to take out the Mobridge and have them enable the CDC, then put it back in. Note for Dension, the light goes from bose amp to Dension, from Dension to HU (as described in manual)
  7. Hi, I just want to let you know that the water drain hose (runs off water from roof/rear hatch channel) is just above the connector to the rear sensors. You'll see it inside LHS rear bumper above exhaust tip. So every time you wash your car, the connector gets wet. You might want to check this and protect from getting wet.
