TopGun2000
Everything posted by TopGun2000
  1. RL seems to provide better protection than M1 but it's not on the porsche approved oil list though...
  2. front rotors get worn out pretty quick. you can measure the thickness of them to make sure if they are still safe to use also need sensors + hardware kits
  3. Are you sure the emissions warranty would cover turbo related issues? I've just noticed there is a small oil leak from the passenger side turbo charger. Update: not the turbo, just a small oil leak from the valve cover, should be very easy to fix
  4. based on the advice on this board, you may not want to mix different brands of coolant with porsche supplied coolant.
  5. I use this online parts catalog: Porsche Parts
  6. I fixed mine by bending the mate pins inside the headlight connector a bit to get a better contact with the female connector new parts are not needed
  7. hmm... went to walmart but they couldn't do it then went to the dealer they said they can't just cut the blade they have to dup the key and remote together...
  8. oh well, too much hassle to remove the air filter box, i will wait for my new parts to arrive to fix the problem...
  9. definitely caused by the mount kit and the back connector not being mated properly i ordered parts (#20) 955 631 041 02 and (#23) 955 631 239 10 but i think your trick should work at 0 cost. maybe i should just return the parts.
  10. oops, just found out that my "fully loaded" 04 CTT doesn't have the option code listed
  11. hmm... can't find the remote on their website. maybe i should get a used one from ebay.
  12. Stealer in Bay Area wants $260 for the remote and $80 to reprogram it. :o
  13. http://www.amazon.com/Northern-Tool-and-Eq...8539&sr=8-1 http://www.amazon.com/Pela-Oil-Extractor-6...8539&sr=8-7 http://www.amazon.com/Mityvac-7400-Fluid-E..._pr_product_top are they going to work?
  14. Kragen has a promotion for mobil 1, something like buy 4 bottles (6.99 each) get 5th for free What do you guys think of these Fumoto Engine Oil Drain Valve Quick drain plug
  15. so did you try to fix the bent wheels or just replace them? just found out one of the factory 20" on my ctt was bent. wondering what i should do
  16. how about 20" factory turbo wheel specs? need to replace one due to some damage on it, and the weight difference between the factory one and replica?
