m4ttc
Everything posted by m4ttc
  1. Taped the whole screen using detailing tape. No difference. The noise still kicks in. Thanks anyway Regards Matt
  2. Hi Thanks Just around the whole rubber seal? or the top where it meets the roof edge or the bottom where it meets the plastic tray. Thanks again Matt
  3. It is like a high pitched electrical whistle that gets louder. I seems to come straight out of the cluster in front of you. It starts intemittent and within an extra 10mph is very high pitched and loud. It seems like feedback maybe? This may also be my imagination but I only seem to get it when the weather is dry ? How easy is it to remove the cluster Loren? Thanks again Matt
  4. Thanks Loren The reason I ask is that I am getting an electrical high pitched noisein y 06 997 that appears to be coming from the dashpod that kicks in around 90mph. Is is speed dependent as starts a little intermittent but then gets louder and constant the faster I go. It is like an electrical restistance noise. Could this be a faulty dashpod or have you come across anything similar Cheers Matt
  5. Does anyone know if the 997 dashpod is the same for the C2 and C2S except for the colour of the dials or are they specific to the car?
  6. We are not talking about the imbeded antenna, are we? mmmmmmmm ;)
  7. £210 is bout $400. ....To swap 4 wheels over! I want to change 18" Turbos for 19" Cayenne Design. Dealer says that PCM settings need to be changed even if there are no TPMS? The rolling radius of the wheels is the same...just less tyre and more wheel. What is the change is the PSM?? I only take delivery of my car on 1st march Cheers Matt
  8. are they the same type/size for 18" turbo and 19" cayenne design?? Sorry for such a daft question Cheers Matt
  9. Thanks Loren..can you tell me what this part is 955 044 602 01nac Ive been told it is on these wheels also
  10. If you change the size of the wheels??? Seems hard to believe. Dont have TPM or PASM. I find this hard to believe especially as he is charging me £210...to do it. Does this PCM thing sound right?
  11. Hi What did you use to remove the rear badge? Where did you buy the silver replacement from? Cheers
