voodoo2000
Everything posted by voodoo2000
  1. $25 donation to Renn Tech 8.99 british #'s! now clue how much that really is...... Having tunes again.... Priceless! The # from Renn Tech was one digit off... started with 7363, turns out it was 7364...I have the CDR220 model, so if it doesn't work with the two digit separation, try one up. :clapping:
  2. Try 7363 or 7361 looks like I'm in the 5% club... thanks for the attempt. tried 7361, 7363 and 7365, a no go.... have reset and will attempt 7359 and 7377 using the 2 digit recommendation - any other suggestions? Did you read the FAQ?
  3. Try 7363 or 7361 tried 7361, 7363 and 7365, a no go.... have reset and will attempt 7359 and 7377 using the 2 digit recommendation - any other suggestions?
  4. Have Boxster 2000 S, need code for: Becker 4462 48/98 X 5025946 thanks for info in FAQ - turns out I was given the wrong serial # info from the prior owner. The TP button confirmed the # given was wrong. Thanks for your help!
  5. 2000 Boxster S was given copy as follows: BE 4462 Y 5035894 with code of 6948 it doesn't work - have not tried to remove radio to confirm serial just yet. other code options would be appreciated! Thanks!
