2porky
Everything posted by 2porky
  1. RS has been at the local porsche centre for 7 days, just got it back today.Yes the old RMS problem has come to haunt me.While the engine was out they also split and rectified oil seepage from the crankcase halves ,Wow! what a major job!Good job its a warranty claim,was told the RMS alone would be 2k job out of warranty!Good to have it back in my garage in mint condition and a credit to the technicians to not mark the car in any way.Fingers crossed the problem has been cured.
  2. Did you ever get a response to your question? I am looking for the same paint code information. can help with this one,i had small stone chip on wheel two touch in,Touch Up Applicator 911 095 932 20 041 is the part number.
  3. Get the UView 550000 Airlock Purge Tool Kit - about $100 US. Do a search here for UView - several have used this kit. Thanks paul,got away with no problems filled it up as follows. Put new rad in position and pushed the hoses on minus the clips. Released the filler cap and got a friend to add coolant while i took the right hand bottom hose off till coolant was flowing through,pushed hose back on and then pulled small hose of on top of rad and waited for more coolant to come through. When coolant came through put hose back on,then put all the hose clips back on. Filled up to max line then screwed cap on then pulled bleed valve up(rear of filler cap) Started engine and left to tick over for 5mins coolant level went down so stopped engine and topped up again,then started engine again. Left to tick over and slowly increased revs to 2-3 rpm coolant level remained stable so put the bleed valve to normal position. Did 3 or 4 miles and check temp and coolant level both was ok. Car now running fine and booked in next week to local porsche centre for its 2 year minor service.
  4. Had to fit new centre rad on my gt3 rs ,stone puncture.Fitting new one want advice on how to refill bleed ect...the cooling system.Can it be done without any special equipment. Thanks
