Ahsai
Everything posted by Ahsai
  1. Thanks for the tips! I raised the spoiler and losen those hex nuts, then retightened them. It helped. After I sprayed more silicon lube on those two fat "hinges", the squeak is almost all gone. Thanks! - Ahsai
  2. Hi Richard, Thanks for the reply and tips. However, I tried that and it didn't work in my case. The squeak sounds like it's coming from the middle of the spoiler (where the actual motor mechanism is, I think). The squeak is worst when it's close to fully up or fully retracted. Thanks, Ahsai
  3. It's squeaking when I use the switch in the foot well to raise it. Anywhere I can lube? I saw a few small hinges but I think the squeak is coming somewhere deeper inside the rear deck assmebly. It's an '03 coupe if that matters. Thanks, Ahsai
  4. Hi, just wondering if you were able to fix it? I have the same problem with my steering wheel. Thanks, - Ahsai
  5. I've driven a few 996's. Engaging in the last inch is definitely too high. The clutch should engage close to the mid-point of the stroke. Regarding the pressure, the easiest is to try another car (maybe at the dealer).
  6. Thanks, buddy. The concern I had over the brushing are streaks and runs. I've never seen one in person up close so I can't comment. But I can tell you if you spray, it looks perfect even up close. Anyway, you can try the brush paint first and if you don't like it, you can always redo with spray. Yea, yellow would be striking on your car! Good luck!
  7. Hi Sid, I painted my friend's '99 calipers with dupicolor high heat spray paint followed by a high heat clear coat 1 yr ago. I've attached some photos. Basically, you need to roughen up the surface with sand paper and steel brush (not down to the bare metal though). Then clean the calipers throughly with brake cleaner. Then spray 4 to 5 light coats of red (20 minutes apart) followed by two heavier coats, then apply the "Porsche" stencil, then a few coats of clear coat. We did everything with the calipers on the car so we didnt' mess with the hydraulic. However, you need to mask a everything else since the paint droplets will get EVERYWHERE. If you take off the calipers, it would be very easy to spray paint. If you take your time, the spray paint will look no different than the real ones! The finsihed surface will be as smooth and glossy. No runs or streaks at all. The calipers still look like new today. - Ahsai
  8. Is there any specific reason given by WD as to why they wouldn't touch the S? Just went to their site input the type of Porsche I have and a pop up stated vehicle not covered by WD. I tried it with different years and States with same results for 911s. Porsche must have some kind of rep for repairs...hehehe... Um...I just tried the WD site and they seem to cover 2003 or newer 996's in California. They don't cover 2002 and older "911s" though. Their CA program has been suspended though but it may resume shortly according to WD. - Ahsai
  9. Have you tried Mind Over Motorsports (off Miramar) and All German Auto (in Escondido)? I've heard good things about them but have not tried personally. Good luck, - Ahsai
  10. I've done a lot of testing on both the dipstick and gauge. To get the most consistent reading, it's best to check the oil level in the morning with the dip stick and top it off to ~1/8" below the MAX mark (so at operating temp, the oil will be very close to the MAX mark). Even though the manual says check the oil at operating temperature, practically you need to wait at least 10 minutes after shut off before you could get a consistent reading plus I found the engine temp could change the tip stick reading a lot (about 1/4"). The hotter the engine, the higher the reading. Say if you had a spirited drive and red lined a few times before turning the engine off, then wait for 10 minutes and check the oil. The level will be like 1/8" higher. That's why checking in the morning will give you the best consistency but keep in mind that the oil level will be a little higher at operating temp. Whoever did the RMS should have cleaned up the mess around that area (so they could identify any new leaks in the future). You may want to keep an eye on it after you cleaned things up. Hope it helps. - Ahsai
  11. Hi, I have an '03 C2 and the passenger seatbelt catches when I pull it at normal speed (not jerking it), it will catch after I pull a few inches or so and if I release it and let it retract a bit, it will allow me to pull further but the same thing repeats after I pull a few more inches. It's as if the autotensioner is way too trigger happy and "thinks" there's a collision and hence locking the belt. It's not the chidseat self-retcheting mechanism that's locking the belt. It's the normal locking you will experience if you jerk the belt quickly except I did not jerk the belt. I also let it retract all the way before pulling the belt but that didn't help. If it's the autotensioner, is it an expensive item to replace? ****, car is only one week out of the original warranty... Thanks! - Ahsai
  12. I use PIAA xtreme white plus (same wattage as the standard) in my other cars and they're great. They're DOT approved so they're legal in the US, not sure about in EU. Philips Vision Plus claims to produce 50% more light but have not tried it personally. Not sure about UK spec'ed cars but in US, '99 uses H7 55W for low beam. - Ahsai
  13. How about connecting a 10A ammeter in series between the battery the the car (via the "+" terminal) and with the engine off and all lights off, check how much current is leaking. I think anything less than 100mA is kind of normal (e.g., alarm). If it's leaking like in >1A, it could be some light that you cannot see (e.g., the lights inside the front trunk). Now, you can try to pull one fuse at a time to see if that stops the leak. Hopefully with some educated guess, it may not take too long. Good luck. - Ahsai
  14. Ok, dealer found that the booster was the culprit. It was full of water inside! One seal is broken that allowed water inside the booster. Got new booster and all the resdesigned parts. Problem solved. - Ahsai
  15. Ok, we flushed out the old yellow fluid with Superblue. The old fluid didn't look dirty at all. The problem is still there but the clutch feels smoother though. When I opened a bleeder and pushed the brake pedal, the pedal went all the way smoothly but when I released my foot, it stayed down and did not return! My guess is a bad master cylinder. We also checked the spring on the pedal but it's really hard to tell how much it's pulling the pedal but it looks fine. The spring is pulling the pedal very close to the pivot point by design, which means it does not have much mechanical advantage. Any thoughts? Thanks, - Ahsai
  16. Argh, I asked my friend to look again and now he found the spring :) Anyway, I'll check it myself later and post an update. Thanks, - Ahsai
  17. There's no return spring at all on the '99! I think the return spring is a '00 feature. There's no other obvious problems in the pivot areas. Is there a spring inside the master cylinder that pushes the pedal back? Thanks, -Ahsai
  18. We couldn't find any brake fluid flush on the car record (he just got the car) so it's hard to say. We'll plan to try a brake flush first and go from there. Thanks, - Ahsai BTW, it seems to be getting worse now to a point I have to use my toes to lift up the brake pedal after depressing it. It just won't spring back by itself and it's as if the vacuum is sucking the brake pedal down. - Ahsai
  19. My friend's '99 996 coupe's brake pedal returns slowly after the foot is off the pedal. It takes like half a second to return completely and it's very noticeable. The brake fluid may need changing but does it indicate something wrong in the brake master cylinder? Any help will be appreciated! Thanks, - Ahsai
  20. Hi Thorsten, You may want to spray the cracks and crevices in area with a little bit of Wurth HHS2000 lubricant (but make sure it won't stain the lining). I have an '03 coupe (so roof is diff than yours) but had the exact symptoms. I srpayed ALL the sliding/moving, stationery parts plus all the springs with the Wurth lubricant and it cures the problem like a charm. Any parts I could see that make any contacts or they wear, I spray. The HHS2000 is a clear lubricant like WD40 consistency when sprayed but will stick on the surface when dried and it's water proof. I use it everywhere, hinges, garage doors, etc. Good luck! - Ahsai
  21. Check this out http://www.pca.org/panorama/sample_article_3.html - Ahsai Check this out http://www.pca.org/panorama/sample_article_3.html - Ahsai Argh..never mind...there's no x-74 there. Sorry. - Ahsai
  22. You may want to check your owner's manual. Mine (an '03) has a few "rpm vs speed" plots on each gear at the end of the manual. - Ahsai
  23. Hi, I have an '03 C2 (so e-gas). If I put it in neutral, it's very hard to give gas to maintain a low engine speed (1k - 2k). When I give a little gas, the engine will rev up all the way to 2k and there's no way I could make it stay at, say 1.2k, 1.4k, etc. even if I hold the gas pedal at a fixed position. Is that normal? Thanks in advance! - Ahsai
  24. Hi, I just had my original clutch replaced at the dealer under warranty. The clutch material was deformed on the flywheel side. I notice the part number of the new clutch disc is 997-116-013-10. Does anyone know the difference between the new disc and the original one, assuming the oringal one starts with P/N 996-...? Any help will be much appreciated! - Ahsai
  25. Ah, yes. The car must be taken to "any smog check station". I guess because the car has 66,000 miles on it. I used the following shop for my bimmer and they're fast and cheap: Lo Sieu Smog Test Only Ctr 6670 Miramar Rd San Diego, CA 92121 (858) 535-1919 - Ahsai
