azelaya
About azelaya
  • Birthday 05/18/1974
    San Pedro Sula, Cortes, Honduras
    Porsche Cayenne Turbo 2004
azelaya's Achievements
  1. Hi there I have similar problems in my Cayenne turbo, and i change the this 2 hoses and the pipe that appear on the following picture and the problem was solve, the hoses and pipe have cracks. Maybe you have to check your if they are ok. Sorry for my english Tito
  2. I have the same problem in my 04 CTT and the problem in my case was the servotronic in the steering rack, i just waiting for my new steering rack. I hope that help you
  3. i bought the pump kit from ecs, couldn't belive the price. looks brand new to me. and it includes the piston oring and the screws which sold for almost 200 at VW dealer. put it in, problem solved. be careful when you hook up the air hoses. i had leak on one of them and had to redo it. the whold thing is located at the passenger side under the doors. use some soap water to check for leakage after you done. it is a diy job but if you have access of a lift, that will make it much easier. hope that helps Hi there i can't belive to, when i go to the ECSTunning and order the air suspension pump repair kit $9.90 + shipping WOW, hurry up and order , here is the link http://www.ecstuning.com/Search/Es289283/ES289283/
  4. Hi there, I just buy my repair kit from ecsTunning and i think they have a error on there website because my cost , $9.90 for the complete kit , not only the bolt and o ringand seal, but inclued the hose and part of the compressor, if any one have this problem by fast and order from here , before they fix it, i call and they say that price is ok, and if you buy only the bolt, o ring and seal i will cost $180.00 Crazy. Here are the links http://www.ecstuning.com/Search/Es289283/ES289283/ complete and $9.90 http://www.ecstuning.com/Search/Es414705/ES414705/ only bolt, o ring and seal $184.00
  5. Hi. Im really new the help, i have a cayenne turbo 2004 with 70,000 kilometers and a have ploblems with the suspension, when i drive my car it feel like im driving in the sport mode because is so steef the suspension, when i press to confort or nomal nothing happend, in the dashboard change but the car is feel the same. Can some one help me anyone with this problem ? I dont have a duromet o piwis, to find the code, and in my country dont have a porsche dealership Help pls someone Arnaldo
  6. Hi there i have the same problem, Yellow air susp faulty always on permanently, i have change the battery to a new one. Can someone pls post the part # ofmthe rebuild kt from VW . Thanks everyone for the help. Arnaldo
  7. Hi there i need help, in my Country is dificult to find tires sizes and good quality, and i have on my 04 cayenne turbo 275/40/R20 and i only find 275/45/R20 you think i going to have any problem with this sizes of tires? can i used this tires? im not using the tire presure sensor. thanks
  8. Hi there i need help, in my city is dificult to find tires sizes and good quality, and i have on my 04 cayenne turbo 275/40/R20 and i only find 275/45/R20 you think i going to have any problem with this sizes of tires? can i used this tires? im not using the tire presure sensor. thanks
  9. Hi guys sorry for mi inglish How did you know that the drive shaft was failure? because i have a sound when i turn my stering wheel to the right, sound like a bump sound, thanks for your respond
  10. Hi. Sorry for my inglish. lol a phone module on a pcm, I have the same question i like to know if my car have it. my car is a cayenne turbo 2004 germany version and have the GSM TRAY in the PCM and the phone button in the upper part of the radio, but when i putt a gsm chip nothing happen, somthing else how do i know what model is my PCM ? the SW version Say 3.0 pcm 3.0 System Software 6635 Device Type. Thank for your help.
  11. Hi, thank you for the share, it's a very clear wiring diagram. Do you know where can I found the same thing but for the new 2009 Bose amplifier please ? Thank you. Hi anubis. Maybe you can tell me where do you find the TBS for the wiring diagram and the TBS number. Thanks.
