:thankyou: :renntech:
This post became a lot longer than I intended. I will state a sort of "legend" to this "map" of tangents in the Gear-Thinker's tangent of a post that I have now, while sitting out back, late at night, smoking a cigar, taken to a degree and length it was never intended to go. Also, my questions (below, larger font, and red) which are numbered, will have information relating to them numbered in their fields of BOLD, UNDERLINE, and ITALIC
BOLD - this will refer to people and information regarding such questions. As in, so if you just read the question and don't see what I have written in proposing the question and what I know, before thinking of me as a fool asking for silly help. This is something I am likely doing, as it seems many of you have written answers to my questions, some such answers contained information I already knew and should have told you I had known, another reason this post is so long;
UNDERLINE - which will contain unrelated stuff, unrelated questions, humor, and all other miscellaneous editorial stuffs that I wrote;
ITALICS - which contain information not backing the questions, but still relevant to the subject at hand;
{This will be question #1} From what I know, Red Compound is the loctite needing to be heated to over 140 degrees Fahrenheit in order to loosen (as I ask later in this post, if I am wrong about this, please let me know). I can see how this would be a huge benefit in keeping them from loosening, but, should that CV Shaft EVER, and I mean EVER need replacing, I will need a torch, which I do not have easy access to, especially when you consider that if the shaft ever does snap, the joints break, etc., I will be unable to replace it as easily wherever the car breaks down, as I will need to move a torch to the right place. To my knowledge, these tend to have a habit of going bad around 100,000 Miles. I may, also, decide to replace both shafts at higher mileage (currently 20,003 Miles on my 1999 Porsche 986 Boxster, a low mileage garage queen... er... king...)
{This will be question #1} I did consider the Red Stuff, but, essentially, I was worried that it was TOO permanent.
{This will be question #1} I currently feel as if, since I've already purchased the Blue Stuff, it makes the best sense to use it, and, should the bolts (which I just got in from my order today, 8X50MM, Allen Head, the correct size, to my knowledge, for the car) ever come loose again, after being torqued past 60 lb-ft of torque (as I believe Maurice had found in his Bentley shop manual - something I intend on getting my hands on as soon as I get some cash... my birthday is the 27th of May, maybe I just found my present...), I will resort to that final measure of the Red Stuff (compound 262, I believe, as stated by WVicary).
{This will be question #2} Maurice, is there any way you can give me a better idea what the difference between M8 an M10 is? Are they the MM of the head of the bolt? The bolts I needed are 8MM by 50MM. They connected the CV Shaft Joint to the Differential. If there's any way to give me an idea of the which one of the two torque specs I need, that would be super helpful and much appreciated. If not, no biggie. My plan would be that if I CAN torque them to 60 lb-ft, I will, but if anything past 29 lb-ft seems like I'm gonna snap a bolt or mash the threads, I won't push it.
I hate to be a penny-pincher, but I'll definitely hear your thoughts on the subject. Because I'm low on dough, Half-Jewish, and Half Fresh Off the Boat Indian (the combination of which stereotypically forces me to be a real miser when it comes to spending money if I don't have to). In the interest of saving money, I have a concise plan, which I will share;
My plan at the moment is to get both my friend who helped and my car (if he's unavailable, I am able to do this by myself, or using some of the kids at the place I'll do the work at to help if absolutely necessary), bolts, and loctite (blue compound - 242, medium strength according to Henkel - the company who makes loctite, as well as many other industrial, automotive, and other glues, sealants, etc.) to the local high school's auto shop.
It's only a couple miles down the road, and if I spring the little cash required for a socket to fit the old bolts, I can make sure they make it to the shop, where they have three hoists. I plan on going there tomorrow on my way to work, to ask the teacher who runs the Auto Shop, an old family friend, as well as my teacher when I went to that high school, when a good day to be there is. Hopefully, I can do this on all Friday, May 21st, where I will have enough free time from 7 AM until 12 PM, when I need to be at work.
I will also, time and possible payment from my never-paying company's parent company, permitting, do an oil change. Then I will remove the wheel, compress the suspension, and remove the old bolts. As suggested, I have already planned on cleaning the all the threads and bolts, so that the loctite 242, medium strength, blue compound, works at it's best (now, if anyone has used the loctite 262, red compound, heavy strength stuff, and has been easily able to remove it, please, let me know, as I have expressed earlier my hesitancy in using it). After thoroughly cleaning the inside threads and bolts, I will apply loctite 242, and use a torque wrench to get them to the 29 or 60 lb-ft of torque suggested via Maurice from his Bentley Manual. I think it would be best to do the oil change after putting in the new bolts, so that I can allow the loctite to take hold before driving to work.
{This will be Question #3} I am pretty sure that when the bolts start to come loose, they come loose and fall out almost immediately, due to the continuous spinning and vibration. Other than checking ever couple of days if they're tight or not, does anyone have any fresh, new ideas?
The rest of this is about how I have been getting around, but before that, {This will be Question #4} I would like to ask you all one last question; I am considering joining the PCA (Porsche Club of America), and noticed they have some Mid-Ohio track courses, which is something I really want to get into, as I honestly would love to be able to enjoy my car to its fullest extent without fear of prosecution (speeding tickets). Is there anyone who has been or plans on going to some of these Mid-Ohio PCA courses this year? I would love to hear about them. If so, please PM me, and I will also, after posting this ridiculously long post, browse the forums in search of "local" area threads and sections.
By the way, I have been on my 2004 Kawasaki EX250 "Ninja", the older style Ninja 250cc motorcycle, for the past few days, and may continue, as I am low as all hell on money, and at over 50MPG, nothing beats it for commuting off-highway, with no passengers. I got caught for the first time ever in the rain on Monday here in Southeast Michigan, but Tuesday thru Friday was/is supposed to be clear skies, as it was today. I am thoroughly enjoying riding in this weather, 60-80 degrees and sunny. I really am not a great rider. I have spent two of my four (including this one) seasons without spending serious time on the bike. Interestingly, those seasons, when I do ride, I see no justification for why I don't ride as much as possible.
As I assume many of you who read this are/have been riders at some point, you understand what riding is like. I am a late bloomer, in terms of both skill and knowledge in both cars and bikes. I love both, am a fairly decent driver, especially for a teenager (19 in less than a week). My skill in driving has steadily improved, from not knowing how to drive at all to being able to heel-and-toe in less than two years, the concept of which was explained to me by a friend, and I taught myself on my first car.
Sadly, in the seasons I hadn't ridden much, I ended up not progressing as I did in driving. It is my goal, however, to ride as much as I can this year in the interest of becoming a skilled rider. I know my areas of weakness, and oftentimes deliberately pick routes which take me through areas where I need to compensate for such weaknesses. Unfortunately, it feels less special when knowing that it is my only form of transportation these days, but, when both car and bike are up and running, I must say, having to choose between which set of keys I'm taking is a tough but wonderful decision.
Question #1 - Is the Red Compound easy to remove, should I ever need to remove these bolts in the event that the CV Shaft needs to be replaced?
Question #2 - Mainly for Maurice, what do the M8 an M10 references mean, and based on what I know about my bolts, what do I use for the torque specs?
Question #3 - PCA members, specifically those in the Midwest, have any of you ever been to the Mid-Ohio PCA track/driving courses, what do they entail, and if you are in Michigan, Ohio, or Indiana, will you please PM me? Also, I will browse the site at some point to find any, if at all, local sections, threads, etc.
Question #4 - I am just curious if anyone has any other ideas of how I can keep those bolts tight, yes, no?
