Sunnyside
Everything posted by Sunnyside
  1. Correct. I'm confused though :( This diagram shows me something different... Got it from pelican parts website... http://www.pelicanparts.com/techarticles/911_static_timing/911_static_timing.htm This is Correct.
  2. Well here is some good news for you then......, there is a guy on 6speed that has sourced all the seals required and bearings as well. Have a search and I'm sure you will find the post. I will have a look now as well.If i find it i will past it on here. Frank I'm sure its all in here: http://www.6speedonline.com/forums/996-turbo-gt2/216574-whats-your-tippy-tip-tronic.html And: http://www.6speedonline.com/forums/996-turbo-gt2/193207-tiptronic-information-thread.html Join 6speed and ask him his user name is Adam699
  3. I have to second that about the leather and also the door cards......Swizol double noted :clapping:
  4. I have PCM, I wonder if that is different. My car is an October 2002 car so its a 2003 model. I definitely didn't do anything with wires when I removed the PCM for repair.?? Apart from that sorry I cant be any more help. Frank
  5. I sent my PCM away , as the card reader failed, i drove the car for 3 weeks without the PCM . My 996tt 1s October 2002. I dont remember this wire your talking about. Mind you at the time I didn't have a Durametric so I wouldn't have known there were any faults. In Fact for the 3 weeks, if I didn't look at the hole left by the PCM I wouldn't have known it was missing. :) The attachment is a snippet from the wiring diagram. Hope it helps a little bit Frank Doc2.doc
  6. Sorry for asking, but are you getting problems with the car or did you find the faults by accident after putting the Durametric on the car. For eg does the alarm keep going off,are you getting any external indication that the car has faults. What made you put the Durametric on in the first place. Sometimes these cars can make your life a misery trying to get them perfect. Its sometime better just to accept there not perfect. Sorry for asking, I do mean well and I'm not having a go I assure you :) Frank
  7. Did you clear the faults using Durametric and try reading the faults again. Some times these type of faults are temporary. The modules only has to sense a glitch to log a fault. I keep getting the odd alarm fault like yours. Sometimes a micro switch will be a bit slow to operate . The mirror motor on my passenger side shows a fault even though it works ok.Once a fault has been logged it will not clear its self, you will have to do that. Untill you do, you wont know if you really have any faults ata ll to worry about. So I wouldn't go spending too much time tracing the faults you have listed until you know for sure they are hard faults and not just glitches. Frank
  8. I have a durametrics cable. Do I plug it in the ODB port and the computer while I drive the car??? Sorry I am pretty new to this. Hi, I assume its a genuine Durametrics cable, so you should have the disc and loaded it onto your lap top. So yes, open up Durametrics, enable logging, shut down Durametrics and then re-open again. Take the car for a run do pulls from idle in 2nd, 3rd and 4th. You should really take to car to the red line but I know that would mean exceeding the speed limit in 3rd by a long way so do what you are comfortable and ultimately safe doing. Without taking the car for a runThings that could show up in codes are cylinder misfire, lambda problem codes etc, you wont have to drive it to find them they will already be logged in the computer from your previous drive/problem. Things you could log driving ( with a passenger as a helper) are boost pressure, revs, lambda for bank 1 & 2, ignition angle, IAT's, engine load. Post up any codes you have. Frank. ps I must say to be fair to the tuner have you talked to them about the problem?? No Cel, code and check engine light what so ever. I just thought that if the plugs were bad, there would be some kind of code pop up. I did talk to the tuner, the person that's familar with the matter was not available(late Friday afternoon) This thread is not about to bring any negative impact to their reputation. I just simply hope to fix the porblem ASAP. Also, hope that future customers would know what to do when these kind of problems arise. From what I have learned so far about these cars, if the plugs are worn, there is very rarely cel codes unless the misfire is bad enough for the ecu to register it. I still think plugs could be the problem. But know doubt you will post the outcome when you find out. Frank Frank
  9. I have a durametrics cable. Do I plug it in the ODB port and the computer while I drive the car??? Sorry I am pretty new to this. Hi, I assume its a genuine Durametrics cable, so you should have the disc and loaded it onto your lap top. So yes, open up Durametrics, enable logging, shut down Durametrics and then re-open again. Take the car for a run do pulls from idle in 2nd, 3rd and 4th. You should really take to car to the red line but I know that would mean exceeding the speed limit in 3rd by a long way so do what you are comfortable and ultimately safe doing. Without taking the car for a runThings that could show up in codes are cylinder misfire, lambda problem codes etc, you wont have to drive it to find them they will already be logged in the computer from your previous drive/problem. Things you could log driving ( with a passenger as a helper) are boost pressure, revs, lambda for bank 1 & 2, ignition angle, IAT's, engine load. Post up any codes you have. Frank. ps I must say to be fair to the tuner have you talked to them about the problem??
  10. Get the car on Durametrics if you can. But importantly change the Plugs. Sounds like they dont like the higher boost. Gap could be well worn, which could explain your problem. Frank
  11. Exactly, thats why its a pain in the ar*e fault when you first get it. In-fact , because the regulator will work for a while whilst the engine and alternator are cold it makes diagnosis very hard. But rest assured,when the diode pack fails you dont get the red charge light on the dash. Frank
  12. I tell you now , it will more than likely be the diode pack on the alternator( Rectifier). Very common fault. Reads good voltage when starting the engine from cold, but slowly as you drive, normally 30 minutes< the voltage drops. Check the voltage when the engine is warm. Cold might be 13.5 but as it warms could drop as low as 10 V. Thats when the world falls apart and all the alarms come on. Frank
  13. Depends on what your running and power levels. Standard 996tt has a good OEM filter. Once you start to tune then it is always recommended to put a more "free flowing " filter on. I have been using K&N filters since 1983. Firstly on my Hillman Hunter Holbay and every car since!! They do make a difference, but IMO only if the car has been tuned to make use of the extra air flow. Frank
  14. Do I understand it correctly,when you say engine went out you mean it stopped on its own. So your boss did not switch it off?? If you have no further problems I would suggest all that happened is that the car stalled ( the engine stopped) This would bring up all the dash lights and alarms. The usual failure is the oil pressure sender to the gauge. When this fails the car brings up an alarm telling you its failed and to take it to the workshop. If your boss has only stalled the car then there is no problems at all. If your boss got a message saying there is a problem with the sender/gauge, then this is not such a big thing at all. Just get it changed. The main thing is if the car is running with good oil pressure at the moment then there is nothing to panic about. Good luck. Tell us all how you get on. Frank
  15. Hi, Could you please explain again: started with an apparent drop in oil pressure (I was not driving, engine went out, oil pressure warning on. What is an apparent drop in Oil pressure. Did the oil pressure drop off when you were driving the car? Or was it at Idle?? What do you mean "Engine went out"?? How much pressure did the car loose, at what revs, does it start, does the oil light still stay on all the time??? Have you checked your oil level in the car, have you checked the oil pressure sender has not failed??? As to the little bit of oil on your finger, I wish mine was so clean. Its an engine, they leak a little bit. A leak becomes a problem when it drips, what you are showing from the picture is merely a weep. IMO dont worry. If the head gaskit had blown normally, the oil would be in your coolant or would be getting into the cylinders so it would smoke!! Frank :unsure:
  16. Hi, They are held on with set screws and captive nuts. The captive nuts are held in place with clips. The shields are not welded on. If you want to replace the screws you will have to remove the whole exhaust. They are very prone to corrosion even thought they are stainless!! Typical Porsche $hit fixings. As you will have found out already even the nuts on the Turbo holding the full exhaust /silencer will be very badly corroded. Its a pain job to do , so it depends on how bad the rattle is. If you go to the trouble of removing the exhaust why not think about fitting a sports exhaust?? Frank
  17. Hi Keith, Firstly, get the car running and go for a long drive 40 mins to an hour. Give it a good run. Check the voltage on the dash to start and keep an eye on it. I suspect your alternator voltage rectifier is playing up. Very common fault and if the alternator isn't hot it will look absolutely fine...........until it gets hot. Then the voltage will very slowly start to drop on the dash. May get as low as 10.5V. This is a sure sign the V reg is on its way out. Putting it on a tester machine will not show this defect until the alternator has got hot. Give it a try. As to 0.9 amps thats not bad at all, do you have a tracker. After 5 or so days the car will shut down most electrical systems it can automatically. Its a Hibernation mode. So .9 amps doesn't sound too bad considering its not In Hibernation. Frank
  18. Hi JP Yes your right, Spoiler is completely different system. Whats the problem with it?? Frank
  19. Hello Frank! If you use "drive link" you can select any of these solenoids (4 total) and in idle you should see the engine rumbling when one of the solenoid is selected. If there is no change in RPM either while selecting the valve opening solenoids or the cam advance solenoids, then you know one of the solenoid is not working.... This is the Durametric version 5 but I also saw it in version 6... Hi JP So its just a case of select the desired valve and if its working the engine should change rpm's/rumble. I was going to have a play last week but decided not to experiment with any of the drive links I'm not sure about. Thats great, thanks mate. Frank
  20. BUMP As I wouldn't mind finding out a bit more about checking variocam solenoids. I have a Durametric, but what should you see with Durametric for faulty variocam solenoids as opposed to good ones. Frank
  21. You wont get any codes, it will save you quite a lot of weight and the car will be quicker. You could also fit the larger GT2 Fuel Tank .However I think you will miss the added safety of the 4x4 and you definitely will notice it missing especially in the wet. Should you have an accident attributable to loss of traction your insurance company will laugh at you if you try to make a claim. You dont even have to fit stub axles as you can remove the drive shafts and leave the CV casing as they are. They make great Stub axles. But think carefully about removing the diff and shafts and centre VC, its a lot of work just to find you loved the 4x4 set up. Frank
  22. As JP says, just change it and you will have a good alternator again. Always good for a spare. I didn't keep mine as there was a surcharge on the new one which I got back when I returned the old one. Frank
  23. Hi mate, Trust me on this, I am an Electrician and it took me ages to work it out. I had the AA out who put a tester on and it was found to be ok. The alternator will work fine on start up but when it heats up it will start to slowly fail. Taking it off and putting it on a test bench will show nothing as the alternator has to get hot as the engine warms. It is most likely the diode pack . Thats the classic symptom . Frank
  24. How do they get around using main items like DME & control units. They all have to be coded into another car. you need the codes from the IPAS system. I thought it was to make things hard to sell on?? Frank
