Brian D. Barrett
Everything posted by Brian D. Barrett
  1. May seem like a dumb question but what should the volt meter in the dash show when you are starting the engine. I have no idea how old the battery is but it seems to be labouring at times to start. The voltmeter goes down to 10 volts and then seems to hesitate and then after the car turns over a couple of times it fires up.
  2. With all the tal of "original paint" how much of a sin is it to paint the front clip on my car? There are a lot of small stone chips and I can only cover them up with coulored waxes for so long!
  3. The small covers over the roof rails where the roof top carrier attatches are hinged on little plastic holders. I have one that is broken And the cover will not stay closed. I know how to remove the roof rail strip covers etc, but can the plastic part be changed and the cover re-installed without removing the interior panel and taking off the entire hinge assembly?
  4. In order to remove odors from the AC system I sprayed a product for that purpose in the main AC outlet over the control panel in the dash center. Two minutes after -- all the AC panel lights went out, all functions stopped working. I contacted the dealer after I had checked all 5 fuses related to "AC' and they were fine. He suggested that computer in the AC unit control head panel itself was toast, or it just shut down for some unkown reason. Anyway whether the spray triggered some sensor or not I have no idea but after I shut off the ignition for 1/2 an hour it came back - this happen to anyone else?
