Iwu3
Everything posted by Iwu3
  1. It worked! I just had to push the up key. Thank you very much for your time. Are you reading this off the radio it's self? Did you try the display on the front panel instructions in the Lost Radio Code FAQ? Code is still 8956 Then 8956 should work.
  2. Yes, I am reading the serial number off the screen.. I followed the instructions exactly on the FAQ. Are you reading this off the radio it's self? Did you try the display on the front panel instructions in the Lost Radio Code FAQ? Code is still 8956
  3. Loren, you're right. The correct serial number is T5001507. I'm not sure if that is an S or a 5. Sorry for the inconvenience.
  4. Try 8956 Try 8956 Thank you, but that did not work. I tried the 2 number increments, but no luck prevailed. Are there any other numbers I can try?
  5. Hello Loren, The battery died in my 993. Becker CDR 210 R2896 TS5001507 Thank you in advance, Ivan
