Tobbe Vågstedt
Everything posted by Tobbe Vågstedt
  1. HI Loren ! Thank you for your answer, i've talked today with porsche center and the guy there told me that i could be the low octan fuel ( 95 ) that i drove on, now i have erased the fault in the log and filled up the gas with shell V-power instead. i have been out for a test run for an hour now and now sign of fail indication. could it been that the oxygen sensor only responded to the low mix of fuel ? do ypu thing that i should put one of those redline fuel cleaners in the tank to really clean the oxygen sensors ? by the way , the gt3 only has one O2 sensor, what i could see. looking forward for your response. Thanks ! / Toby
  2. Hi. Does anyone know if there is anything i can do to fix my problem i've got these codes and the car has only 65000km and is an 2004 i understand that the problem is with the cat conversion banks 1,2, could it be because i filled it up with unledded 95 instead of 98 ( i've only done that twice .....) ? is there any major difference on 95 or 98....? is there anything i can do instead of changing the cat's ? / Toby from sweden
