Click here to Donate
UB330
  • Content Count
    2
Everything posted by UB330
  1. Hi, is there anyone that have installed the ViseeO MOSTO (MO-S1-B) in a Porsche with PCM 2.0/21 and solved the conflict with original mounted telephone? I have tried to pull out the cables fron the phone devise under the passenger seat but still i rendomly get the message "Error phone" on the display. If i then press 1+4+8 at the same time the Viseeo shows up again. Is there a way of turning off the signals from the original phone? Fuse? Or do i have to program the PCM so it doesnt look for the original phone and is that possible in Durametric proffessional? Thanks for any advise... :-) //UB3
  2. Its very easy retrofit a Cayenne (2003-2010) with Cruise Control. Buy a stalk from Touareg or av Q7 from the scrapyard and fix a cable from pin #5 in the stalk and connect it to the grey/yellow cable at the DME pin #A38 an use PIWIS to code "steeringcolumn" and "DME" that Cruise Control is fitted on your car. Very simple and your car is "upgraded" witha small piece if labour!
