darrinsmith
Everything posted by darrinsmith
  1. Hi Does anyone know if the tow bar and control unit from a gen 1 cayenne (2003) will fit and work with a gen 2 cayenne. I am looking to upgrade my 2003 to a 2008 but the 2008 doesn't have a tow bar which I really need. Can I take the one off my 2003 and fit it to the 2008? Thanks DS
  2. Thanks! On the internet they seem to be more commonly known as 5 point torx security often prefixed by the letter "TS" rather than "TX" like the normal torx. I have located several sets on e-bay, so I'll get a set and see how I go. Thanks! DS
  3. Hi I am having real trouble getting the MAF sensors out on my 2003 cayenne turbo. They look like torx security bits #20 or #25 but I just can't get my bits to fit. I can get the MAF out easy on both my 996's(N/A and Turbo), they have torx security #20's from memory. (Tip after removing them replace them with normal phillips head screws) Am I missing something? I just cleaned the MAF on my 996 turbo and man what a difference, solved all sorts of crazy hesitation problems and feels like it liberated an extra 50 HP!. Want to try the same on the cayenne, but feel like a bit of a fool that removing four screws has (pardon the pun) screwed me! Can anyone who has removed them on the turbo comment? Thanks! DS
  4. There are some stainless steel X50 headers on ebay (Australia) from time to time, they say they will fit the regular 996 turbo, which I have (MY2004). I wonder if there would be any improvement (over the really cool stainless steel look). Anyone care to comment? Thanks DS
  5. Hi again Roger, Where is the Cab's bass box located? Is it in the front trunk? Thanks Darrin Smith
  6. Hi The dealer has confirmed that this part (the bulb holder) is NOT available as a separate part, you have to buy the entire headlight assembly, which they kindly offered to me at a discounted price of $1,000! Needless to say I declined the offer! The bulb holder is available as a separate part for 2002 onward cars (costs about $36!) but is unfortunately not backward compatible. Cheers DS
  7. Sorry to reopen this old thread, but I also need this part for my 99. Dealer is clueless as it doesn't appear on the parts catalogue, wants to sell me the part from a 2002- which won't fit of course. Can anyone shed any light on this part. I could re-build my old one (it rusted out) but i'd rather fit a new one. Thanks DS
  8. Hi it sounds like you have accidentally broken the optical loop. Have you cheked all the connections? The optical loop needs to work just like that, a great big loop, think of it as a highway with only one way traffic that goes around in a circle. I found the install instructions from dension excellent, I had mine up and running in about 30 minutes, with the BTA1500 bluetooth. I did not have a cd changer though, so i didn't need to remove it from the loop. I definately sounds like the loop is broken somewhere. I also assume you are talking about the gateway 500? you didn't actually tell us. Cheers and good luck DS
  9. Thanks Loren, that was my understanding. Roger, what problems, if any, did not disabling the PCM cause in your car, given there will be no screen to display errors on. (It just may be a while before I can get to a shop with a PIWIS so if the problems are bad, i may hold off on the installation so i can make time to get the car in). Thanks! DS
  10. I fixed mine by cutting off the broken hose below the one-way valve down to just above the 90o bend. I used some 1/2 inch vaccum hose to slip over the remaining pipe and bend. Then I clamped it with a hose clamp, and clamped the other end to the bottom of the one way valve and re-inserted the one-way valve into the top part of the pipe. Total cost about $10 and 30 minutes time, plus the new hose is so thick it'll never crack again. Error message went after two starts and a bit of a drive. Cheers!
  11. Hi I am about to embark on the same thing on a 04 Turbo Cab Is it necessary to "delete/disable" the PCM in the MOST ring using the Porsche system tester, or is it ok just to swap everything out and patch the optical ring where the PCM used to be. Thanks DS
  12. Hi Does anyone have the part number for the lower hose? Mine is split also, done a quick fix with tape, but it should be replaced. Couldn't find any reference to the above mentioned part number in the PET. Thanks DS
  13. Hi My 03 turbo did the same thing. I'm just using the normal key at the moment. I haven't been able to locate the unit, near the stering wheel in my RHD car, so suspect it is acually on the passenger (left) side in RHD cars. How much did your unit cost? I'm not looking forward to replacing it $$$$$ Thanks DS Perth
  14. Sounds strange. I did front pads and rotors the other day on my 03 turbo, and the rotors almost fell off by themselves after the retaining screws were removed. Same on my 996, just pulled them off by hand.. At most they should need a gentle tap with a rubber mallet. Cheers DS
  15. Thanks Loren you beat me too it.. DS I think I just found the answer, the part ending in 60 is for the 2002 carrera onwards, while the part ending in 53 is the for 99-01 carreras but also fits the cayennes. Thanks DS
  16. Hi I wanted to know if anyone can comment on whether the oil filter insert is interchangeable with the 996 3.4 engines. The parts guy at the dealership told me they were, although parts numbers are slightly different. 996-107-225-53 (955) vs 996-107-225-60 (996) I've done plenty of oil changes in my cayenne, and bought bulk filters and seal rings. As I said Parts at the dealer said no problem, but they have been wrong before..... Just wanted to check before I dump the oil on my 996. Cheers DS
  17. Hi My 03 turbo starting doing this after I switched to K&N filters. Annnoying but appears harmless. Does not generate any error codes in the ECU. Cheers DS
  18. Never mind found a multi size set on e-bay M6-M12 that should do the trick... They're special order at all the local shops... Torx and multi point are similar, but not identical and knowing my luck if I use a torx, I'll strip the bolt head :-) Thanks DS
  19. Hi I have to change the plugs on my 03 TT but no-one here stocks the multi-point bit (we call it Spline-Drive here). I have the M10 used for removing the seat to change the battery, but the bolt on my stabiliser bar is larger. It looks like a M11 or or possibly M12. Can anyone tell me exactly which size it is as I have to order it sight-unseen and they do not allow returns for special ordered tools. I have seen references to a T-55 but it is definately not a torx drive bolt. Thanks DS
  20. Hi Q8 Helper Ok for soft sand you need tyres that you can let down to about 18psi to get some traction. I use 18" wheels on my turbo currently running Maragioni Maxo's. As for lift, I have air, so no problem there. You don;t need so much lift for sand if you can keep the momentum up. It's when you get stuck you need lift. Also do a google search for Maxtrax. They are great in sand. Check my other posts for more sand driving tips. I also only just watched that video. Man, that is a prime example of how NOT to drive in sand dunes, you NEVER EVER drive across a dune, only up and down (you'll roll as the soft sand downhill gives way, (believe me I've seen it happen) and you NEVER EVER go flying over the top of a sand dune like that, unless you have checked the other side, you can get wind cut outs that make sheer drops that will flip your car for sure and smash the front in, again I've seen that happen, NOT PRETTY especially when you're miles away from Medical attention.... Cheers DS
  21. Hi Replaced the battery but no joy. Off to the dealer :-( Cheers DS As a side note, the replacement battery recommended by the Australian Varta distributor was a AGM (Gel Matt) battery. I have one in my camper they ae good, no venting required and can mount in any position. They gave it to me at the same price as the wet battery (which was half price!) so I took it. DS
  22. Hi The rear window on my 99 cab finally let go last night separating almost all the way along the bottom seal. (I've only had the car back a week after a transmission rebuild :-( ). I've put the hard top on (ugly) but the roof has got to come off to either be repaired or replaced. I've searched the forum and seen lots of talk about it but has anyone done it themselves? I have the factory workshop manual and have read the procedure several times. It seems tricky, but not impossible, just a bit time consuming. I also have the durametric software, the latest beta bersion claims to be able to do the top calibration. So I was just after some feedback from anyone who has done it themselves and any tips they can offer. I have been quoted around $600 for labour and about $400-$500 for a new window, but I am also considering the GAHH glass conversion depending on the cost of repair - although the top itself is in very good condition. Also does anyone know if the roof mechanism can be folded down with the top removed, so I can still drive the car with the hard top on while it's getting repaired. Looking forward to your responses.... Cheers DS
  23. Yeah that was my main concern also in summer it easily gets to 40oC plus
  24. Hi My local auto shop has a special on Castrol Edge 5W-30 fully synthetic oil. It's half price! normally costs a little more than the Mobil 1 5W-40 I normally use. I'm looking for an opinion on this oil. My main concern would be that 5W-30 would be a bit "thin" for the hot climate we have here. The oil is marketed as being suitable for "high performance modern turbo charged engines" and "extreme temperature". Any opinions? Thanks DS
  25. I upgraded from a 97 Boxster to a 99 996 cab, several years back. Do it, you'll never look back. As Jeremy Clarkson says on Top Gear "The only reason you buy a Boxster is because you can't afford a 911!". I know that's why I did. The back seats are a good size for little kids. My 6 year old son loves it! The main difference you'll find apart from MUCH better straight line speed is the 911 is certainly not as forgiving in the bends as the Boxster. You will learn to become good friends with copious amounts of understeer compared to your Boxster. But it's all part of the learning curve. If you get a cabriolet (why wouldn't you!), fit a strut brace, even my wife noticed the difference.... Best of luck DS
