996
Everything posted by 996
  1. I'm replacing my clutch using the sach's clutch kit. The gearbox has been removed but I have not removed the pressure plate or the clutch yet. Do I need to replace the bolts which attach the pressure plate to the dual mass flywheel? When removing the pressure plate as I do not have the porsche special tools, can anyone give some light on an alternative to stop it turning whilst un-screwing the 6 bolts? Also as I do not have a porsche centring manderal can I use a universal clutch alignment tool when fitting the new clutch? regards
  2. See the post right before yours... Where do I top up the pentosin fluid? does it do into the pump or the rams? The hydraulic cylinder can only be filled in a retracted position. Position the hydraulic cylinder vertically and fill with 5 ml Pentosin (per hydraulic cylinder) using a syringe. my spoiler is in the lowered position, is there a manual way of lifting it up so that I can remove the wing and pumps? I've tried putting a 12V supply to it and I can only hear the motor running with no movement. I also understand that there is a special tool required to remove the rear wing from the rams, is it absolutely essential that I use this tool or can I use something else to substitute. many thanks
  3. See the post right before yours... Where do I top up the pentosin fluid? does it do into the pump or the rams?
