diverzeusy
Everything posted by diverzeusy
  1. carman3. An indy would charge $350-$400 from reading around the forums about this
  2. Ahsai please can you forward 996TT wiring diagram to me? gas.safe.engineer@gmail.com thank you paul :thumbup:
  3. Quote from tutorial Use ramps or jack up the vehicle at the points provided. I guess that means jack at ALL points on the car , therefore it will remain level? does this sound correct? or can you raise only the rear? Thank you
  4. Hi Meljohnson i do not think any waranty will change coolant pipes unless they are actually leaking. are your pipes leaking?the best place to try and see/feel is at the rear right side of the intake through a small hole.
