ralfman5
Everything posted by ralfman5
  1. I have a 2005 turbo that's burning a lot of oil. When I first turn on the car I get blue smoke and like 3 seconds then normal smoke. I know a vent line was broken and lots of oil near there. My mechanic fixed it. But I checked oil level and its getting low. Any possible problem??
  2. what are the symptoms or example of electrical faults? should i try a new battery or a new control unit? also i should check the wirring on the control unit?
  3. park assist code 430:parkassist display panel(light segments) front right faulty code 431:parkassist display panel (light segments) rear faulty
  4. i recently purchased a 2005 Cayenne turbo, and i have an issue with the park assist. when i start the car, you hear the beep for the park assist, then on both display only the left and right red light turn on and it does nothing else. when you are at stop or driving at slow speed they also turn on. on the durametric it says front and rear display failure. any solution to this problem?
