Thomas Pxrry
Everything posted by Thomas Pxrry
  1. Did you ever find the source of C152 - Communication PSM Control Unit (Drive) ?
  2. Did you ever find the cause of p2198? I seem to have the same issue
  3. Recently I developed a glovebox light issue on my boxster 987 s I Attempted to replace glove box light with led and now it doesn't work at all, even with the standard bulb is put back that worked before, nothing. Attempted to swap with the footwell bulb and light housing, nothing Following this when locking the car the horn would sound So ... I Replaced the cable attached to the bulb holder part 99761265100 (glove box wiring harness). This includes a small metal switch that is pushed into a holder at the back of the glovebox This solved half of the problem, The car horn no longer sounds when locking However the light in the glovebox still is not working Swapped it again with the working footwell light and still nothing All of the other lights I replaced work perfectly. As I am aware there is no fuse for this bulb So how is it fixed. Even porsche themselves are confused????
  4. Hi Paul It had a brand new micro switch, new bulb holder, original bulb and still it refuses to work Very annoying
  5. got it!Do you know if the glove box has to be removed to get access or can it be accessed without remove the assembly? And do you happen to know the part number
  6. got it!Do you know if the glove box has to be removed to get access or can it be accessed without remove the assembly? And do you happen to know the part number
  7. Hello Paul Currently have the same problem with my BOXSTER S 987 http://www.planet-9....-fix-809-03.gif Glove box Attempted to replace glove box light with led and now it doesn't work, even with the standard bulb that worked before Following this when locking the car the horn would sound So I Replaced the cable attached to the bulb holder part 99761265100 (glove box wiring harness) includes a small metal switch that is pushed into a holder at the back of the glovebox This sounds half of the problem, The car horn no longer sounds when locking However the light in the glovebox still is not working Swapped it with the working footwell light and still nothing All of the other lights I replaced work perfectly any ideas of how this can be fixed? As I am aware there is no fuse for this bulb So how is it fixed. Even porsche themselves are confused.
