Search the Community
Showing results for tags 'alarm logic system'.
  • Search By Tags
  • Search By Author
Calendars
  • 911
  • Boxster
  • Cayenne
  • Macan
  • Panamera
  • Taycan
  • Classic Porsches
    • 356 Series
    • 911, 912 Series
    • 914, 914-6 Series
    • 928, 928S Series
    • 964 Series
    • 993, 993 TT Series
    • 980 Carrera GT
    • 918 Spyder
  • Events / News
    • News, Information, Rumors
    • Events
    • Work on Cars (SF Bay Area)
  • Other
    • Lost Radio Codes
    • Workshop Tools
    • Porsche Trivia
    • Forum Features Explained
    • Post Testing
Categories
  • Contributing Members Only
    • Tools and Diagnostics
    • Other files/documents
  • Public
  • Option Code Documents
    • Boxster
    • Carrera (911)
    • Carrera GT
    • Cayenne
    • Cayman
    • GT3
    • Macan
    • Panamera
    • 918 Spyder
    • Turbo / GT2
  • Service and Wear Parts List
    • Boxster
    • Carrera (911)
    • Carrera GT
    • Cayenne
    • Cayman
    • GT3
    • Macan (95B) (MY2015 - 2018)
    • Mission E
    • Panamera
    • 918 Spyder
    • Turbo / GT2
Categories
  • 911
    • 992-2 (911 Carrera) - DIY
    • 992-1 (911 Carrera) - DIY
    • 991-2 (911 Carrera) - DIY
    • 991-1 (911 Carrera) - DIY
    • 991 (Turbo, Turbo S) - DIY
    • 997-2 (Carrera) - DIY
    • 997-2 (Turbo) - DIY
    • 997-1 (Carrera) - DIY
    • 996 (Carrera) - DIY
    • 996 (GT3) - DIY
    • 996 (TT/GT2) - DIY
    • 993 (Carrera,Turbo) - DIY
  • Boxster
    • 718 (Boxster, Cayman) - DIY
    • 987-2 (Boxster/Cayman) DIY
    • 986 (Boxster) DIY
  • Cayenne
    • 9YA (Cayenne) - DIY
    • 92A (Cayenne) - DIY
    • 9PA, 9PA1 (Cayenne) - DIY
  • Macan
    • 95B-2 (Macan) - DIY
    • 95B (Macan) - DIY
  • Panamera
    • 971-2 (Panamera) - DIY
    • 971 (Panamera) - DIY
    • 970 (Panamera) - DIY
  • Taycan
    • Taycan Turbo, Turbo S - DIY
Categories
  • Cars For Sale
  • Parts for Sale
  • Tools for Sale
  • Items for Trade
  • Wanted
Product Groups
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Interests
From
Present cars
Future cars
Former cars
Found 1 result
  1. This is Part II of the process of trying to find out why fuse C3 blows as soon as I put the fuse in. This disables the things in the title and prevents the doors from locking other than the driver's door with the key. Story started August 13. So far I have done the following (some unrelated) without finding the solution: 1) Checked battery, voltage was low (12V) due to low output from alternator; changed voltage regulator. Now runs about 13.5 volts. Bad battery is apparently main cause of alarm logic failures. Replaced both oil temp. senders. 2) Looked at wiring diagrams which led me to fuse C3 which was blown. Replaced it and things lit up. Shortly thereafter fuse C3 blew. 3) Removed seats and checked the condition of alarm logic box on driver's side. Disconnected airbag connectors on both sides. Replaced fuse C3. Everything worked. Put airbag connectors back together and everything still worked. 4) Removed headliner. 5) Put seats, etc. back in. Fuse C3 blew. 6) Bought PST2 laptop clone on eBay. Learned something about it and troubleshooting with it. Found out about Diagnostics Manual that was sitting right on my computer. Learned about IPAS codes which are required to activate and teach modules (e.g., "program" new key). Dealers are reluctant to give people their codes even after showing proof of ownership because they don't want to lose out on the money if people fix their own cars. There is also a security issue. But, there are dealers that will provide the codes. You just have to find one. 7) Replaced Passenger Compartment Sensor (senses presence of either kind of passenger - driver or passenger) and central locking switch. Fuse C3 blew. 8) Left front turn signal stopped working. Changed bulbs, worked on socket for about two hours. No help. Swapped sockets/lamps left to right. Problem followed socket/lamp. Right turn signal now not working. Ordered two new sockets. Got in car next morning and both turn signals were working and have continued to work ever since. No affect on Fuse C3. Sockets are cheap - $13 and are the major cause of turn signal failure. Turn signal lamps last longer than sockets. 9) Removed fuses D8 & D9 to isolate the removed PCM module from power. No help. So, almost a month later I am about $1200 (including $50 worth of 15 amp fuses :blush:) poorer and still have same problem. I am resisting the temptation to buy a new alarm logic module until I've done more testing. The modules aren't cheap, but not outrageous. The diagnostic manual has whole sets of troubleshooting sequences for each of the alarm module codes. Yesterday, I had alarm logic module codes 34,60,61,47,46,10 &11, I reset the codes. This morning I had just 47, 34, & 60. Later this morning I reset the codes, drove home from the store and still have no codes. I could go through the diagnostic procedure for, lets say, code 34. However, there are only two solutions for fixing a code 34. One is to replace passenger compartment sensor (already done) and repair wiring harness. So, I need to check wiring harness for problem and repair it - what wiring harness? The two that go to the alarm logic module or the one that goes to the passenger compartment sensor? For code 47, first check input signals from doors that are not locked. If PST2 indicates Driver's and Passenger's doors not locked (which mine did), check door locks. The following steps include removing connectors from door locks and from alarm logic module, checking continuity between terminals. This means taking door panels off (?) and front seat out. But, the only two options for repair are repair wiring harness or replace alarm module. What wiring harness? The diagnostics for code 60 are very clearly written but has lots of steps. Since I already know that the central locking switch is not working (but, it is good because its new (?), so I think its not working because fuse C3 is blown) I go to step 5, 6, and 7 or 8 which say to repair wiring harness or to step 9 which says to repair wiring harness and then maybe to step 10 which either takes us to check fuse C3 or repair wiring harness or replace alarm system control module. Step 11 is not feasible because during the few short times fuse C3 stayed closed long enough to lock the doors with the key fob, the doors locked. So, the door locks are OK. My conclusion is that I should check every wiring harness in the front of the car or replace the alarm system control module. Maybe I should just buy an alarm system control module. "Andraya, please ship alarm module". Mike
