First DIY Brake job, help needed
Firstly I've read and searched a lot on these forums. So any questions I have are due to stuff I could not find.
MY 2000 Boxster S.
This will be my first brake job. I am planning to do front + back, pads, rotors, fluid flush.
My brake lights have not come on yet, looks like the pads have 3-4mm left in front and rear. The rotors are at 22 and 25mm.
I have 4 new zimmerman rotors, 2 new rear pads (2 front ones come in another week), and ATE blue and amber fluids.
Questions:
-I think I need to paint the rotors. Where do I spray the paint? front and back? whole rotor? Should I cover the disc area with painters tape?
-Can I use the old front pads with the new front rotor for a week or so until I get my new pads?
-What order should I do stuff in? Flush, then rotors, then pads?
-Any wierd tools that I will need? I will have a helper thus won't need a powerbleeder.
-The new pads are Hawk HPS (Should get them in a few days). Do I need to drill holes for the sensor? If so, how do I do that? Do I need special tools?
-Anything else I should know? I will be following the Bombay digitial tutorial as well as Loren's tutorial.
Dig a little deeper in the DIY forum here. There is a lot of info on brakes. Also, check out this post:
http://www.renntech.org/forums/index.php?showtopic=6864
and this link:
www.bombaydigital.com/boxster/projects/brakes/
Good luck with your project. I did mine and it was pretty easy. You can read about my experience in the post above.
Later,
-pvaughan
