In the right ball park?!
I have a Porsche PET cd and I'm some what confused on looking at the info. In the remarks it has a 02- on one part number (p/n) and an 03- on the other p/n and the 03- has a model number M 450 in the model number. When I did a part search on this site, it came up for around $5K for the price. Is that the price for a PCCB brake disk? I need correct p/n's for the front and rear so I can order them to replace my brake rotors/disk because I have a warped one and I might as well change them all along with the new pads I have. Also need torque specs and p/n's for the screws that mount the rotors to the hubs. Can you help me out?
TIA! :help:
:renntech:
M450 is PCCB.
If you have steel brakes then you want:
996.351.409.02 Left Front steel rotor
996.351.410.02 Right Front steel rotor
996.352.405.00 Left Rear steel rotor
996.352.406.00 Right Rear steel rotor
Torque is 7.5 ft-lbs. (10 Nm) = not much
I was surprised on the torque value, thought it was way higher than that. Thanks Loren! :clapping:
