alarm/remote retrofit?
I have looked at the wiring diagram, and everything is connected to the alarm control unit - door locks, interior lights, door switches, monitoring sensors etc, etc, etc. I can't find a wiring diagram for a car without an alarm so I suspect that you have the control unit, but maybe not all the connections. It is under the driver's seat in a LHD car, or under the passenger seat in yours. Obviously your car has some of the functions - central locking, for example, but if the control unit is the same then you can probably add some of the functions, but you may have to add sensors, etc. Unfortunately, there is only one way to find out - try it.
If you want the wiring diagrams for the alarm, PM me.
edit: Looking at the PET
For your MY there are 3 control units shown:
986 618 260 00 - Option M531 central locking but no alarm
986 618 260 00 - Option M534 with alarm
986 618 260 01 - Option M535 with alarm 315MHz
If yours is the same part number as the alarm option, maybe you could retrofit parts, but like I say, there's only one way to find out.
It would probably be more cost-effective to get an aftermarket remote alarm fitted though.
Edited by Richard Hamilton
Thanks a lot, Richard. Will check out the control unit when I get a chance.
  • 11 years later...
I know, I had a full head of hair when you wrote that. Thanks for the response. Remote locking units are quite cheap these days and the estimated cost of fixing mine here in Australia is looking like thousands only to risk it failing again (just after its warranty is up). So I am looking at the possibility of connecting an after market unit with the existing wiring. Ever heard of this, I have seen one thread but it suggested there may be some shortcomings. Would appreciate your thoughts or experience.
Regards  Ron  (Adelaide South Australia)
