i don't think so.......
i used a flap disc and made the mouth wider and thinned it out also, so i will have to see how it works when i get home
this mod actually helped to get the drivers side off in no time at all.
BUT after removing the right side, I bent the threads on the ball joint........
I am assuming that i need to replace the entire control arm.
depends on how much you bent them. i bent them on my rear control arm once, but not too bad. i used a small file to file away the two threads i bent very carefully, and managed to get the nut back on. i have since gotten a huge assortment of taps and dies because the filing was a little hit or miss. but study it - see what is bent, and see if you think you can remove a couple of threads - it is cheaper than the 200 - 300 control arm.
Yes, it's possible... isn't removing the ball joint what you were trying to do in the first place? The procedure is just like Highlander posted on page 1, using the tool everyone was pointing you towards. You'll have to grind off the bent part of your old ball joint, too, I think. You need a ball joint removal tool, and when you apply enough pressure (and WD40) it pops out. Then, another special tool + more pressure inserts the new ball joint. It was $10 for a new ball join the last time I had to change it on a domestic, so probably about $200 for this one ;)
Edited by grover
i was popping the ball joint out so i could swing out the hub, so i could remove the axle. I am replacing the cv boots. Replacing a ball joiont was not in the picture on this project.
I have done many things in the past but never ball joints of all things
I would replace the damaged joint, the threads could be damage but it could have hidden faults like stretched threads which could break under loading.
called my indep. mech and he has never done these like most people. I ordered a used control arm from dc automotive in NC. I will never make this error again when disconnecting a ball joint.
