Hi all. I recently picked up used 04 996. When I put down the window and put it back up, it leave long oily traces on window. It happens on both driver and passenger side. Is this a common problem? Is there a way to fix it? Thanks!
This is pretty common. If it REALLY bothers you, take off the door panels and clean the oil off the little wheels that hold the glass in place.
If not, just ignore it for a while and the oil tracks will eventually go away.
-Charles
