Retrofit Cruise Control to '04 996 GT3
ltcjmramos
If cruise was an available option, I'm sure it could be retrofitted. I've never done a GT3, but it should be the same as an 02-04 Carrera. I don't have a wiring diagram specific to the GT3, so I can't check. Use the same method as the later Boxster/997 - wiring between the stalk and cluster only (ie no connections to the DME) and you will need to get the Cluster AND DME coded with a PST2. I'll PM you some details.
Edited by Richard Hamilton
  • 4 weeks later...
Got the retrofit done at the dealer where I had bought the car a couple of years ago. From the repair order.
Parts:
1 996-613-219-10-EWC, Column switch assy
1 PNA-721-043-00-040, Repair set K - #9600
2 PNA-721-043-00-063, Repair set 03 - #960
10 999-513-007-40, Tie-wraps ($2.45 ea!!!, what a crock!!)
1 PNA-721-043-00-122, Electrical housing #960122
$343 in parts, $225 in labor
NOTES: Installed column switch, and fabricated wiring harness. Coded and verified operations
