Title says it all. I need part number for the following if anybody has them:
1. 4 and 8 degree shims for GT3 rear spoiler
2. Metal valve stems for GT3 wheels.
FYI....2004 996GT3.
Thanks!!!
1. These are MotorSport part numbers so there could be a delay when ordering - check with Sunset Imports. If there is a delay I'm pretty syre Gert at Carnewal.com has these in stock.
996.512.821.90 4 degree shims
996.512.823.90 8 degree shims
2. Check with Jeff at Sunset Imports - I don'tknow if the TT (hollow wheel) metal valve stems will work on GT3 wheels (I've never tried). They might but the hollow wheels are much thicker so I don't know if the metal valves will stick out. Also, the metal valve stems also seal on both the front and inside of the so I don't know if the GT3 wheels have the proper surface for that. BYW... even the GT3 RS uses rubber valve stems.
