My low beam on one side is very dim...I changed out the bulb and still the same. I swap the bulbs around and still dim. High beam one works fine. Any ideas....thanks
Sounds like the light assembly isn't inserted correctly, try removing it and reinstalling the unit. Also the retaining clip that hold the electrical connector inside the fender that mates to the headlight sometimes breaks resulting in a poor contact and in a rare case you can have a poor ground path. Do a search on here and you'll find pics of retaining clip and connectors.
