My rear brakes lights are always illuminated no matter what I do to the brake pedal. Any ideas? I'm assuming there's a switch somewhere that maps the brake pedal motion to the lights? Or I guess they could be binding somehow...
The brakes themselves feel okay to me.
Hi
Look if the switch is activated when the brake pedal is not used. If yes, replace the switch. If not, look for water infiltration in the brake booster ( water drains clogged?? )
Regards
Yes, the lights are On even when not in use.
Where about is the switch? I'll check it with a multimeter this evening.
