brake lights
i had a free inspection of my boxster yesterday, and they informed me that none of the
brake lights worked, and it was most likely a brake light switch failure. where is this swithch located?? is there an obvious way to tell if it is faulty?? :huh:
Yep, your brake lights do not work. Problem with the older cars. You can try to fix the old switch or just buy the newest and greatest new version of the switch. Stick your head way under the brake pedal area and you will see it.
