I am about to buy a code reader, so have been searching the forum for information, seems to be above the fusebox in the footwell
Jim
im not sure what you mean by MY ,MY CAR IS A 1999 2.5 BOXSTER
I'm very surprised it works, but I'm pleased for you that it does! At that price, you can't go wrong.
i plugged it in and it went through the start up procedure ok and then came up with no codes .i tryed it on the wifes 04 vectra and it says linking error
I got a couple Richard, one to leave in each car. If the cat warning light comes on I want to know why sooner rather than later. Used it to get rid of a few codes I got after the 996 had sat for a while (300 series), easier than setting up the computer and the OBDII cable I got a year and a half ago.
I decided to try a code reader despite Richards comments that it probably would not work which is what the code reader seller on ebay also said. Only 2001 on cars in europe, but for £38 i thought why not. The reason for trying it was the engine check light on and rough idle. The car is a 1997 2.5.
Dont know how well it worked but it did come up with 5 codes, 0300 multiple cylinder misfire, and 0301/0302/0303/0305 for each cylinder. I used the Generic scan on the reader. My suspision was the MAF because the check light came on immediately after fitting a new K & N filter to replace the filthy one fitted by the previous owner. I know K & N say it does not affect the MAF but that was my thought. Anyway i took the MAF off and cleaned it with solvent and it seems OK now.
No MAF fault showed up on the reader.
Jim
