disable airbag,light 2.5 1999 uk, boxster
hi, can any,1 tell me how to disable airbag, light on a, 2.5 uk, boxter, the car was involved in an accident about 5, years ago, its been on ever since, thanks.. chris.
I have also just got an "airbag" light set and have tried to clear with OBD II and apparently it requires a PWIS or Durametric tool to read and clear FYI. Looks like a trip to the dealer as a last resort and a search for a Indie with the right tools. I am sure you have read to the links dealing with the likely root cause as "corroded" contacts in your seat belt retainer. Contacts are in the seat belt clasp as I understand it and electrical contact cleaner spray can clear up the problem. I have not tried this cleaning method yet but will in the next few days, tim e permitting. I understand in reading the my search of links dealing with this issuem there was a TB on the problem with the older P cars ( pre-2000) that required the dealer to replace seat-belt retainer or retro-fit gold contacts for originals from the factory. Perhaps your car may be eligible for the retro-fit if it has not been performed as the factory was supposed to have changed to a more reliable contact sometime in the MY 2001 vintage. Good luck with the resolution!!
Demosan
Have the fault code read out, it should be pretty obvious how to fix the problem. If you don't want to fix it, remove the bulb from the cluster.
Todd
hi,tod done just that, today problem solved, thanks for the reply..
hi, demosan went down the seat belt route, but no joy, had the code read this,morning problem now solved and yes it was a, trip to dealer thanks for the reply ..chris
Demosan
Demosan
pOrka,
Glad to hear the problem was solved by the dealer and code cleared. What was the dealer solution?? As I mentioned to you in my original response, I have a similar problem and perhaps I can learn from your experience?? TIA
Demosan
hi, demosan sorry to be of not much help they wouldnt tell me the problem because the guy who done it was on his lunch break, just paid £40 and drove off, chris...
pOrka,
Sounds like it couldn't be much of a problem to solve if it was only 40 quid. Likely a good cleaning of the contacts with contact cleaner. The full contact replace process ( referenced on TSB on this site) implied a few hours of labor to replace parts etc. GLad to hear your problem is apprently solved, and I hope it doesn't reoccur as others have experienced.
Demosan :thumbup:
