soft top transmission timing help
Hey Guys,
I am planning to repair the soft top transmission this weekend on my 98 Boxster. I got all the instructions on how to replace the transmission from this forum (Ton of thanks for that!!!). What I could not find is how do I time the transmission properly so that it closes and opens in synch. Any guidance will be much appreciated.
Regards,
Aman
Edited by aman
The same length for both rods, exactly the same position for the connections ( looks like boomerangs ) on the gearing.
Activate the top and look Wat the cover ( metal shell ) does, to synchronized use the cables, pull them out of the central located motor and turn by hand till you succeed the perfect synchronisation. It most by clear that you use a set of new cables, thy are the source of all the problems.
