Anybody in SF Bay Area with linker adjustment tool?
If you have the new shifter installed (the inside version) then the tool will do you no good - it doesn't fit the new shifter rod.
If you count the threads from the connector end the left (reverse) cable is usually 4-5 threads and the right is usually 6-7 threads - at least in my experience. That should get you pretty close.
If that doesn't work then you will likely have to borrow a standard shifter from someone - install it - then use the tool to align the cables.
Just stick the transmission in Neutral and put the shifter in the "neutral position" and hook it up! (but you knew that already right?) <_<
