Today decided to change the discs on my S. Everything went resonably well until got to the point of pulling off the discs/rotors. They wouldn't budge. They appear to have rusted onto the hub plate. When I did this on my GT3 the discs easily pulled off by hand.
Any thoughts, help or hints would be appreciated.
Fronts, although I'm doing the rears next.
The rotors are rusted on the hubs even after a short time of use, remove the TORX bolt that hold the rotor in place, remove the brake caliper and give the rotor a tap with a hammer from the inside to the outside and the rotor will come off.
