pennyporsche
Hey you really are a gem doing this.
Can you give me a code for a 1997 Boxster, CDR210, R1097, VSO12409. I hope this is the details you are after i followed your instructions which worked perfectly, again thank you and please help.
****Loren, sorry the 0810 / 0812 code isnt working any other i could try? *****
thanks
There is not another try - PLEASE read the FAQ.
Share this post
Link to post
I too need A radio code for a 2002 boxster,2.7 & 5speed. US
CDR220
Type 4462
serial # 15006403
Any help appreciated!
Try 6924
or
6922
If you have not already read this FAQ - please do so...
Lost Radio Code - FAQ, PLEASE READ THIS FIRST
Thanks but they didn't work, I also tried 6920 & 6926. Any other codes I could try?
Share this post
Link to post
Hope you can help...
Lost radio code
2002 Boxster
Becker 1
Type 4362
Ser: 15003359
Thank you
Try 6638
or
6636
Thank you. I tried 6638, did not work and this was my last try. I will try 6636 as soon as the code prompt comes back. I haven't driven much lately. thanks again.
Share this post
Link to post
Hi Loren,
I am re-installing a CR-210 in my '98.
Model: BE 2182
Serial #:5004981
Regards, and many thanks in advance!
Share this post
Link to post
Hi Loren. I'm going to replace a window regulator today and realized that I don't have my code. I'm not sure what happened to it!
The car is a 2002 Carrera 4S.
Here's the information:
Becker 1
Type 4462
Ser 25017172
Thanks very much for the help with this!
Share this post
Link to post
Becker 1
Type 4462
Ser 25017172
Try 0550
or
0548
Share this post
Link to post
Becker 1
Type 4462
Ser 25017172
Try 0550
or
0548
Will do! Thanks!
Share this post
Link to post
Replaced Battery and *sigh* need my code.
2001 996 C4
Becker 1
Type: 4462
Ser #: 15086887
24/99
Val
Edited by DonkeyWorx
Share this post
Link to post
Mine didn't work on my first attempt. It is now on "WAIT". I'll monkey around with it a little more and see if I can get it to go. The good news is - the window regulator replacement was a success.
Share this post
Link to post
Hey Guys,
Can you please help get my code as well
CDR220 Becker1
Type: 4462
Ser: 15061856
Hakim
Share this post
Link to post
2001 996 C4
Becker 1
Type: 4462
Ser #: 15086887
24/99
Val
Try 3117
or
3115
Loren,
3117 and 3115 did not work.
Any more numbers to try?
Share this post
Link to post
Hi Loren,
I just got a brand new second hand 996! Yay! In fixing the other issues I discovered I needed the radio code...
Becker CR220
Type 4362
S# 15002186
Thanks in advance!
Mark
Share this post
Link to post
Hi there, i dont own the car but a friend has just contacted me and asked me if i could find him an unlock code, he said his battery died or something i dont know hehe.
he has no internet so he asked me and this is the only place i could find.
the only info i have is that its a -
CDR 220
serial #E7077511
Edited by shaddes
Share this post
Link to post
  • Similar Content
    • By Kevin Bryck
      2002 996
      Welcome everyone to another installment highlighting the wonderful world of fragile Porsche parts!
      Have both 17" and 18" wheels and have recently lost the metal Center Cap logo medallion off of one wheel of each size.
      While removing the other center caps every remaining medallion fell right off in my hand.
      Metal medallion secured with a random dab of some type of adhesive.
      We have reached the end of lifespan of whatever adhesive the Center Cap supplier used to keep precious colored metal medallions stuck to those cheap plastic caps.
      Anyone know how to remove old adhesive?
      Anyone have any idea what adhesive to replace it with?
      Anyone know how much the Porsche/Piech families made selling replacement center caps last year?
      Remember when paying through the nose for your precious replacement Center Caps that the Porsche and Piech families are the 7th wealthiest oligarchs in the world per Wikipedia.
    • By Loren
      Which radios fitted to Porsche can have their unlock code recovered through serial number?
      - CR-220/CDR-220 - Becker
      - CR-210/CDR-210 - Becker
      - Traffic Pro NAV/CD - Becker
      Which radios can not have their unlock code recovered through serial number?
      - CR1 - Alpine
      - CDR-23/24 (or later) - Becker
      - PCM (Porsche Communication Management) – Siemens & Becker
      How to get your radio serial number?
      CR-220/CDR-220:
      Hold down the TP button for at least 10 seconds after you turn the radio on. "Becker 1" will be displayed. Rotate the right knob (slowly) and it will display the Becker model number. Then rotate it again and the serial number should be displayed on the radio.
      Or, if the radio is out of the car the then the serial number is on the label.
      CR-210/CDR-210:
      Press tone, then 8 and 0 simultaneously. "Becker" appears. Press station up arrow on right. "PR-VERS" appears. Press one of the numbered buttons below the display, directly below the LCD arrowheads (try a few). The model number will appear. Press station up arrow on right. "SERIAL N" will appear. Press the numbered button again. The serial number will appear.
      CDR-23 (or later):
      These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected.
      Traffic Pro:
      Select the Service Menu, press NAV and multifunction key 10 simultaneously in radio mode. Use multifunction keys Nxt and Prv or turn the right control knob to select the individual items.
      You can move through the following items:
      - Model-No.
      - Serial-No. <-- this is what we need
      - Changer Reset
      - GAL
      - Radio Software
      - Radio Bolo
      - Navi Rom
      - Navi Flash
      - RTC Value
      To quit the service menu, press END.
      I get a WAIT on the display - what do I do?
      You have to wait at least 30 minutes before trying again.
      The suggested number did not work - what do I do now?
      Most often when the code we give you does not work it is because the serial number came from an old card in the car rather than from the procedure stated above - or a typo in the serial number submitted. Double check the serial number you submitted using the procedure above again.
      If that does not work then you will need to contact a dealer or Becker. Becker charges to look up your code and some dealers also charge.
      Our program works maybe 99.9% of the time but we have no explanation why it doesn't always work.
      Can you give me a code for my PCM?
      These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/ OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
      Sorry, the only place you can get a PCM code is from a dealer/ OPC.
      Can I post my VIN to get a code?
      We do NOT need your VIN - only your radio serial number.
      Where can I post my lost code request?
      Please post your request here:
      Please DO NOT PM me or email me (or anyone else helping with the codes) your radio code request - we will only answer requests in that one thread.
    • By mdhall54
      I have a 2003 Boxster with the CDR23 radio and external amplifier mounted in the front trunk.  There are two multi-pin connectors, a fiber optic connector and an antenna connector on the rear of the head unit.  The display on the head unit in the car seems to be fine as the display appears to be working as it should.  The problem is no sound out of any speakers.  The problem was intermittent for quite a while as sometimes when I started the car I would have sound from  the speakers and other times no sound.  Sometimes I would be driving and the sound would suddenly just quit.  Now there is no sound at all, but the head unit display still appears to be working ok.  Does anyone have any suggestions as to what might be the problem?
