pennyporsche
Hi need code for 97 Targa Becker radio...
R 1996
serial#: T5001794
Thanks for any suggestions!!
Try 6403
or
6401
THANK YOU!!!
Share this post
Link to post
Loren:
Requesting lost radio code
Becker CDR220
type 4462
ser. # 15086919
Thanks for a great service!
Share this post
Link to post
Awesome, 9579 worked thank you VERY much!
-Nelson
Hi Loren,
I would really appreciate it if you could help me out.
CDR 220
Becker 1
Type BE 4462
Serial No. X5029901
-Nelson
Try 9579
or
9577
If you have not already read this FAQ - please do so...
Lost Radio Code - FAQ, PLEASE READ THIS FIRST
Share this post
Link to post
Hi The mechanics disconnected the battery and the radio code message was prompted.
Would appreciate if you can help:-
Becker 1
CDR22
Type 4467
Serial 15004130
Thanks a lot in Advance.
Rds
Andrew
Share this post
Link to post
Becker 1
CDR22
Type 4467
Serial 15004130
Rds
Andrew
Try 0784
or
0782
Share this post
Link to post
Becker 1
CDR22
Type 4467
Serial 15004130
Rds
Andrew
Try 0784
Thanks. I am sure it works.
or
0782
Share this post
Link to post
Is there anyway to pull the code from the radio before it is disabled? CDR-220.
Bill
Share this post
Link to post
Sorry I was not clearer.
What I meant was is there anyway to have the radio display it's code before it's deactivated by disconnecting the battery?
Radio is working fine right now but will deactivate once I disconnect the battery to install a new ignition switch.
Bill
Share this post
Link to post
Bill
The procedure is the same before or after battery disconnect. See the instructions in the FAQ.
Share this post
Link to post
No radio code..
Becker CR-220, type 4462, X5023685, Thanks!
Try 4399
or
4397
Hi again
Thank you for your suggestions but the codes did not work for my radio. I have tried +-2 several times with no success.
Would appreciate if you have ideas?
einesv996
Share this post
Link to post
No radio code..
Try 4399
or
4397
Hi again
einesv996
PLEASE read the FAQ.
Share this post
Link to post
I have a 1999 Boxter 2.5 and replaced battery and now cannot locate the unlock code.
CR-220
Becker 1
Type 4362
SN: X5013228
Thanks in advacned!
Share this post
Link to post
I have 2002 Porsche Boxster
CDR 220, Type BE 6625, SERIAL# 25014252
Dealer gave me code of 4716 but doesnt work.
PLEASE help me I would greatly appreciate it!
Thank you for your help!
Edited by TiffanyWallace
Share this post
Link to post
CR-220
Becker 1
Type 4362
SN: X5013228
Thanks in advacned!
Try 8422
or
8420
Share this post
Link to post
CR-220
Becker 1
Type 4362
SN: X5013228
Thanks in advacned!
Try 8422
or
8420
Thanks Loren, the code(s) didnt work. Will try more when the radio resets. Thanks for your time.
Share this post
Link to post
Try 8928
or
8926
Share this post
Link to post
I don't have a radio code. Can you help me?
Becker CDR-220, type 4462, W5005555,
Edited by kyny
Share this post
Link to post
  • Similar Content
    • By Steven Powell
      My CR-220 plays the FM & AM & Cassette, doesn't play the 6 Pack CDs. Faceplate does not display, all presets work, and equalizer.  Is the problem in the face plate or radio?  Will getting another faceplate work with this radio?  Will it change the radio code.
    • By Ig.ny
      “Thank you worked like a charm!!!! I have a foxwell, getting error codes 31 ignition circuit - side airbag , driver
      and 21 ignition circuit, driver
      no idea what to do. Horn works depending on its mood. “
      Please help
      Any suggestions  would help. I’ve taken off the door panels and disconnected and reconnected the airbags.
    • By Kevin Bryck
      2002 996
      Welcome everyone to another installment highlighting the wonderful world of fragile Porsche parts!
      Have both 17" and 18" wheels and have recently lost the metal Center Cap logo medallion off of one wheel of each size.
      While removing the other center caps every remaining medallion fell right off in my hand.
      Metal medallion secured with a random dab of some type of adhesive.
      We have reached the end of lifespan of whatever adhesive the Center Cap supplier used to keep precious colored metal medallions stuck to those cheap plastic caps.
      Anyone know how to remove old adhesive?
      Anyone have any idea what adhesive to replace it with?
      Anyone know how much the Porsche/Piech families made selling replacement center caps last year?
      Remember when paying through the nose for your precious replacement Center Caps that the Porsche and Piech families are the 7th wealthiest oligarchs in the world per Wikipedia.
    • By Loren
      Which radios fitted to Porsche can have their unlock code recovered through serial number?
      - CR-220/CDR-220 - Becker
      - CR-210/CDR-210 - Becker
      - Traffic Pro NAV/CD - Becker
      Which radios can not have their unlock code recovered through serial number?
      - CR1 - Alpine
      - CDR-23/24 (or later) - Becker
      - PCM (Porsche Communication Management) – Siemens & Becker
      How to get your radio serial number?
      CR-220/CDR-220:
      Hold down the TP button for at least 10 seconds after you turn the radio on. "Becker 1" will be displayed. Rotate the right knob (slowly) and it will display the Becker model number. Then rotate it again and the serial number should be displayed on the radio.
      Or, if the radio is out of the car the then the serial number is on the label.
      CR-210/CDR-210:
      Press tone, then 8 and 0 simultaneously. "Becker" appears. Press station up arrow on right. "PR-VERS" appears. Press one of the numbered buttons below the display, directly below the LCD arrowheads (try a few). The model number will appear. Press station up arrow on right. "SERIAL N" will appear. Press the numbered button again. The serial number will appear.
      CDR-23 (or later):
      These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected.
      Traffic Pro:
      Select the Service Menu, press NAV and multifunction key 10 simultaneously in radio mode. Use multifunction keys Nxt and Prv or turn the right control knob to select the individual items.
      You can move through the following items:
      - Model-No.
      - Serial-No. <-- this is what we need
      - Changer Reset
      - GAL
      - Radio Software
      - Radio Bolo
      - Navi Rom
      - Navi Flash
      - RTC Value
      To quit the service menu, press END.
      I get a WAIT on the display - what do I do?
      You have to wait at least 30 minutes before trying again.
      The suggested number did not work - what do I do now?
      Most often when the code we give you does not work it is because the serial number came from an old card in the car rather than from the procedure stated above - or a typo in the serial number submitted. Double check the serial number you submitted using the procedure above again.
      If that does not work then you will need to contact a dealer or Becker. Becker charges to look up your code and some dealers also charge.
      Our program works maybe 99.9% of the time but we have no explanation why it doesn't always work.
      Can you give me a code for my PCM?
      These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/ OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
      Sorry, the only place you can get a PCM code is from a dealer/ OPC.
      Can I post my VIN to get a code?
      We do NOT need your VIN - only your radio serial number.
      Where can I post my lost code request?
      Please post your request here:
      Please DO NOT PM me or email me (or anyone else helping with the codes) your radio code request - we will only answer requests in that one thread.
