pennyporsche
Hi there. Same story of the disconnected battery...would truly appreciate your help:
Thank you.
CDR 210
R 3297
W5022032
Share this post
Link to post
Thank you.
CDR 210
R 3297
W5022032
Try 9059
or
9057
If you have not already read this FAQ - please do so...
Lost Radio Code - FAQ, PLEASE READ THIS FIRST
Thank you very much. 9061 (2 more) worked. Thanks again.
Share this post
Link to post
Hello,
Another request, please help.
CDR 220 BE6625
S/N 15006013
VINWPOCA29932S65xxxx
Thank You very much in advance.
Edited by Loren
removed VIN from post
Share this post
Link to post
Neither worked for me. I tried the following numbers:
9669
9671
9673
9675
9677
9679
9681
Should I continue trying numbers? Is it possible to be an even number?
Thank you.
Share this post
Link to post
9669
9671
9673
9675
9677
9679
9681
Thank you.
Yes, you can try even numbers or your dealer or Becker.
I assume you got the serial number using the method in the FAQ?
Share this post
Link to post
Loran,
HELP!
Can you give the code for my radio
4462
X5018607
48/98
Thanks in advance.
Share this post
Link to post
Need Radio Code for 99 Carrera 4
Becker 1
Type 4362
S/N 1500 1231
24/99
Share this post
Link to post
  • Similar Content
    • By Sonsalla911
      Hey Guns,
      i one a GT 3 mk 1.
      it has Original Radio CDR 23And weites Protect.
      when i Check with PIWIS there is a Site with Radio Code which is now 0000.
      i Could change But have no Code.
      who can help me...i thought CDR 23 will Never loose Code
    • By Sonsalla911
      Hallo ,
      can someone help me to change frequence from CR 2200 from Asia to Europe?
      Warm regards. Ingo
    • By Steven Powell
      My CR-220 plays the FM & AM & Cassette, doesn't play the 6 Pack CDs. Faceplate does not display, all presets work, and equalizer.  Is the problem in the face plate or radio?  Will getting another faceplate work with this radio?  Will it change the radio code.
