pennyporsche
Hi I have had my radio reset and do not have a code.
Is it possible for a code to unlock the radio
The details are:
Becker 1
4367
S/N: Y5024261
Thanks in advance
Share this post
Link to post
The details are:
Becker 1
4367
S/N: Y5024261
Thanks in advance
Try 9010
Share this post
Link to post
Normal story... Yet another flat battery and now the radio is asking for a code I do not have!
If you could help finding the code that would be great!
Radio detail:
Becker 22
Model number 4467
Serial Y5035037
Many, many thanks!
Dan
From previous post... It's a 2001 boxster s, uk car...
Not sure if relevant...
Many thanks,
Dan
Share this post
Link to post
Radio detail:
Becker 22
Model number 4467
Serial Y5035037
Many, many thanks!
Dan
Many thanks,
Dan
Try 5451
Share this post
Link to post
The details are:
Becker 1
4367
S/N: Y5024261
Thanks in advance
Try 9010
Loren Thank you much appreciated worked a treat!!!
Share this post
Link to post
Becker CR210
BE 2182
ser # V5008351
I got the two tools and pulled the stereo out. I am going to disconnect the battery soon. I see that at least 25 other CR210 BE 2182's have asked, so it must be the serial number V5008351 that gets the code.
Thanks in advance.
Respectfully;
Rapewta
Edited by Rapewta
Share this post
Link to post
Becker CR210
BE 2182
ser # V5008351
Thanks in advance.
Respectfully;
Rapewta
Try 9464 ...............
Share this post
Link to post
Bruce2010...
You da man!!
Worked first time. Thanks. Once you enter the code... press the "seek" button and
the music is blasting thru the speakers.
Share this post
Link to post
HI Loren,
Code 1435 didn't seem to work. Any suggestions?
Thanks for the help
Hi, Need some help with my radio.
Becker CDR 220
Serial # 15009779
Thank you!
Try 1435
Share this post
Link to post
HI Loren,
Thanks for the help
Becker CDR 220
Serial # 15009779
Thank you!
Try 1435
Then you likely gave me the wrong serial number. You can check it using the procedure in the FAQ.
If you have not already read this FAQ - please do so...
Lost Radio Code - FAQ, PLEASE READ THIS FIRST
Share this post
Link to post
2001 Boxster S
cdr-22
Becker 1
type 4467
serial no. 15001495
24/99
many thanks for providing this to owners.
Cheers,
Try 9860
worked perfect - thanks :-)
Share this post
Link to post
I recently disconnected my battery to recover my steering wheel, but I do not have the radio code now that it is back in and the battery is reconnected.
The car is a 1996 Carrera 2.
The radio is a Becker CR-210.
The Serial Number is S1000044. I retrieved this from the instructions listed on this site.
Share this post
Link to post
Try 0352
Share this post
Link to post
Thank you so much! You saved me a trip to the dealer! That worked on the first try!
Try 0352
Share this post
Link to post
CDR-220
Ser 15000911
Thanks in advance!
Edited by DustinHood
Share this post
Link to post
CDR 220
Ser # 15050187
Radio code 7108
I don't feel the above code is correct as i have to enter it 3 times, and then it goes into wait mode, and then resets back to wanting the code.
what is odd is i have the factory radio code card and t says the SN # is BE 4462 Y 5037949 which is different from the above, when i hold the TP button in.
Thanks for the help in advance.
Share this post
Link to post
CDR 220
Ser # 15050187
Radio code 7108
The radio serial number the unit displays is the correct radio serial number. Likely your radio was replaced and they kept the old card.
Try 8764
Share this post
Link to post
  • Similar Content
    • By Loren
      Which radios fitted to Porsche can have their unlock code recovered through serial number?
      - CR-220/CDR-220 - Becker
      - CR-210/CDR-210 - Becker
      - Traffic Pro NAV/CD - Becker
      Which radios can not have their unlock code recovered through serial number?
      - CR1 - Alpine
      - CDR-23/24 (or later) - Becker
      - PCM (Porsche Communication Management) – Siemens & Becker
      How to get your radio serial number?
      CR-220/CDR-220:
      Hold down the TP button for at least 10 seconds after you turn the radio on. "Becker 1" will be displayed. Rotate the right knob (slowly) and it will display the Becker model number. Then rotate it again and the serial number should be displayed on the radio.
      Or, if the radio is out of the car the then the serial number is on the label.
      CR-210/CDR-210:
      Press tone, then 8 and 0 simultaneously. "Becker" appears. Press station up arrow on right. "PR-VERS" appears. Press one of the numbered buttons below the display, directly below the LCD arrowheads (try a few). The model number will appear. Press station up arrow on right. "SERIAL N" will appear. Press the numbered button again. The serial number will appear.
      CDR-23 (or later):
      These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected.
      Traffic Pro:
      Select the Service Menu, press NAV and multifunction key 10 simultaneously in radio mode. Use multifunction keys Nxt and Prv or turn the right control knob to select the individual items.
      You can move through the following items:
      - Model-No.
      - Serial-No. <-- this is what we need
      - Changer Reset
      - GAL
      - Radio Software
      - Radio Bolo
      - Navi Rom
      - Navi Flash
      - RTC Value
      To quit the service menu, press END.
      I get a WAIT on the display - what do I do?
      You have to wait at least 30 minutes before trying again.
      The suggested number did not work - what do I do now?
      Most often when the code we give you does not work it is because the serial number came from an old card in the car rather than from the procedure stated above - or a typo in the serial number submitted. Double check the serial number you submitted using the procedure above again.
      If that does not work then you will need to contact a dealer or Becker. Becker charges to look up your code and some dealers also charge.
      Our program works maybe 99.9% of the time but we have no explanation why it doesn't always work.
      Can you give me a code for my PCM?
      These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/ OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
      Sorry, the only place you can get a PCM code is from a dealer/ OPC.
      Can I post my VIN to get a code?
      We do NOT need your VIN - only your radio serial number.
      Where can I post my lost code request?
      Please post your request here:
      Please DO NOT PM me or email me (or anyone else helping with the codes) your radio code request - we will only answer requests in that one thread.
    • By mdhall54
      I have a 2003 Boxster with the CDR23 radio and external amplifier mounted in the front trunk.  There are two multi-pin connectors, a fiber optic connector and an antenna connector on the rear of the head unit.  The display on the head unit in the car seems to be fine as the display appears to be working as it should.  The problem is no sound out of any speakers.  The problem was intermittent for quite a while as sometimes when I started the car I would have sound from  the speakers and other times no sound.  Sometimes I would be driving and the sound would suddenly just quit.  Now there is no sound at all, but the head unit display still appears to be working ok.  Does anyone have any suggestions as to what might be the problem?
    • By Douglas Norton
      I have a 2004 Porsche Cayenne S with a Becker radio and Bose system. I understand the radio is a PCM 2. The radio is a CBR23 E1. I had a Bluetooth adapter installed and now my radio immediately goes into PROTECT mode. I tried downloaded the unlock code from an internet service, but there is no place or time for me to enter it in to radio. Any help would be greatly appreciated.
