pennyporsche
Request for radio code.
2002 C4 Cabrio
CDR-220
4462
15002308
24/99
Thanks so much!
Try 6421
Worked like a charm, Thank You for the quick response.
Share this post
Link to post
The Battery was disconnected and I do not have the radio code. I've checked everywhere, including under the front hood behind the badge, as someone had told me it may be written there. The serial number is X5033093. It's a 2000 2.7L 5spd manual. Any help would be greatly appreciated.
Share this post
Link to post
Try 0174
Share this post
Link to post
I also have a lost radio code issue, replaced batt, radio asking for code, can't locate original docs
radio is CR 220 Becker 1, type 4362, SN w5007075, 30/98....need help, thanks
Share this post
Link to post
Try 5375
Share this post
Link to post
cold you help me with my radio?
2001 Boxter S 3.2
CDR-22
BE4467
15045740
Thanks so much!
Try 4963
Thank you! It works perfectly. Great!
Share this post
Link to post
Dear Loren,
I have a cdr220 with seral code :
15040447
I plan to DC the battery to remove the door panel and can't find the radio code. Any help would be appreciated.
Thanks.
Share this post
Link to post
Dear Loren,
15040447
Thanks.
Try 5082
Share this post
Link to post
Works! Thanks a lot, did I mention you're the man!
Please any help would be appreciated.
4462,
Y5061010
24/99
Try 9075
Share this post
Link to post
Try 5375
thanks, Loren....need to run car for 60 min to clear, but will let you know...thanks again
Share this post
Link to post
Hi, I wonder if you could provide me with my radio code
Becker1
CDR-22
Model 4467
Serial No.15046327
24/99
Thanks in anticipation
Share this post
Link to post
Becker1
CDR-22
Model 4467
Serial No.15046327
24/99
Try 9148
Share this post
Link to post
Could you find out what my code is?
Becker1
CDR-220
Type 4362
Serial No. Y5023155
24/99
Many thanks,
Rob
Share this post
Link to post
Replaced Battery... lost code.
Your help would be appreciated.
CR-220
Becker 1
Type: 4362
Ser: 15032088
24/99
Share this post
Link to post
CR-220
Becker 1
Type: 4362
Ser: 15032088
24/99
>>>>>>>>>> 0324 <<<<<<<<<<
Share this post
Link to post
CR-220
Becker 1
Type: 4362
Ser: 15032088
24/99
>>>>>>>>>> 0324 <<<<<<<<<<
worked like a charm!
Many Thanks!
Share this post
Link to post
Becker1
CDR-22
Model 4467
Serial No.15046327
24/99
Try 9148
Thanks worked first time !!!
Share this post
Link to post
I have a CR-220, when I held down the TP button for 10 seconds and 'scrolled' through the options, Becker 1 came up as Loren said, but when I scrolled to the serial number portion it just said, 'seri'. It's a 4362. It also said '24/99' and a reset option...please help...how do I find the ser number?
Edited by leosmith78
Share this post
Link to post
  • Similar Content
    • By Sonsalla911
      Hey Guns,
      i one a GT 3 mk 1.
      it has Original Radio CDR 23And weites Protect.
      when i Check with PIWIS there is a Site with Radio Code which is now 0000.
      i Could change But have no Code.
      who can help me...i thought CDR 23 will Never loose Code
    • By Sonsalla911
      Hallo ,
      can someone help me to change frequence from CR 2200 from Asia to Europe?
      Warm regards. Ingo
    • By Steven Powell
      My CR-220 plays the FM & AM & Cassette, doesn't play the 6 Pack CDs. Faceplate does not display, all presets work, and equalizer.  Is the problem in the face plate or radio?  Will getting another faceplate work with this radio?  Will it change the radio code.
