pennyporsche
I have a CR-220, when I held down the TP button for 10 seconds and 'scrolled' through the options, Becker 1 came up as Loren said, but when I scrolled to the serial number portion it just said, 'seri'. It's a 4362. It also said '24/99' and a reset option...please help...how do I find the ser number?
Try the procedure again. If that fails then you will likely need to pull the radio out to read the serial number tag.
Share this post
Link to post
Thanks Loren...I tried a few times and the serial number is a no-go. I even put a little pressure on the face plate and tried because sometimes I don't get a good "seat"...still no joy.
I did, however, find a manual, written by the previous owner, "code: 4678". I tried to enter this 3 times and locked the unit out...now I'm waiting for it to unlock again. It didn't say it was for the radio, but I'm not sure what else it could've been for.
I'm physically unable to pull the unit out of the dash myself due an injury, but if I can't resolve via other means, I may have to resort to the local Stealer.
So, my questions are, should I try maybe incrementing the last two digits of the above number as I've seen in other posts?
Are there any other things to try when the radio doesn't take the code, assuming that 4678 is the correct code?
Thanks for all your help, I really appreciate it!
Share this post
Link to post
Last resort. Try taking the faceplate off and cleaning the contacts with electrical contact cleaner or an eraser. Then try again.
Share this post
Link to post
Ok, Loren...I found the code...the REAL code. I actually found the radio code card and the code was totally different than the one I posted earlier...see what happens when I assume? Anyway, radio is working...thanks for your help.
Share this post
Link to post
I'd love to have a radio code.
CDR-220
Becker 1
Type 4462
x5024745
48/98
Share this post
Link to post
Just got the 1998 boxster out of winter storage... I have the CR-210 with serial W5010428
Thank you so much in advance!
Share this post
Link to post
Try 4930
Share this post
Link to post
CDR-220
Becker 1
Type 4462
x5024745
48/98
Try 8787
Worked like a charm. Much appreciated.
Share this post
Link to post
Hello, I have an 02 996 with the stock Navigation / radio unit. I changed the battery today and don't have the radio code. How do I get my serial # so i can get the radio code?
Please help! Much appreciated .
thanks,
Ben
Share this post
Link to post
thanks,
Ben
PLEASE READ THE FAQ.
Lost Radio code FAQ
Share this post
Link to post
I think I have the PCM system... does that mean it won't work for me?
thanks,
Ben
Lost Radio code FAQ
Share this post
Link to post
thanks,
Ben
Lost Radio code FAQ
A radio would like this
and PCM looks like this
Share this post
Link to post
Hello,
Need help with a 2001 Boxster S. Battery died and can't get the radio working.
Becker 1
CR 220
Type 4362
Ser 15030823
Thank you!
Share this post
Link to post
Hello,
Becker 1
CR 220
Type 4362
Ser 15030823
Thank you!
Try 6826
Share this post
Link to post
Hello,
Becker 1
CR 220
Type 4362
Ser 15030823
Thank you!
Try 6826
That worked! Thank you so much!
Share this post
Link to post
  • Similar Content
    • By Sonsalla911
      Hey Guns,
      i one a GT 3 mk 1.
      it has Original Radio CDR 23And weites Protect.
      when i Check with PIWIS there is a Site with Radio Code which is now 0000.
      i Could change But have no Code.
      who can help me...i thought CDR 23 will Never loose Code
    • By Sonsalla911
      Hallo ,
      can someone help me to change frequence from CR 2200 from Asia to Europe?
      Warm regards. Ingo
    • By Steven Powell
      My CR-220 plays the FM & AM & Cassette, doesn't play the 6 Pack CDs. Faceplate does not display, all presets work, and equalizer.  Is the problem in the face plate or radio?  Will getting another faceplate work with this radio?  Will it change the radio code.
