pennyporsche
I got a used 2000 Boxster and the previous owner lost some of the manuals. The battery died during winter storage and locked the radio up. Any help would be greatly appreciated.
CDR220
Y5043335
Mariel
Share this post
Link to post
CDR220
Y5043335
Mariel
Try 6547
Share this post
Link to post
I bought the car recently and I installed the gt3 delete console kit and I had disconnected the battery. Now its asking me the code which I don't have.
But here is the info about the deck:
From a 2001 996 C4
CR-220
Becker 1
24/99
type 4362
Serial 15031333
Share this post
Link to post
From a 2001 996 C4
CR-220
Becker 1
24/99
type 4362
Serial 15031333
Try 6821
Share this post
Link to post
Hello
bought a Boxster S 2000 in april. Have look around all the car and read the owner manual to see if previous owner has writen the code somewhere, but didnt find anything.
So here is the info:
Becker 1
CDR220
4262
48/98
X5031697
thanks
wawa
Share this post
Link to post
Hello
Becker 1
CDR220
4262
48/98
X5031697
thanks
wawa
Try 8459
Share this post
Link to post
Hi, just bought 2001 boxster S, radio code was lost with battery change
becker 1
type 4462
cdr 220
ser# Y5052490
THANKS IN ADVANCE
PAWNSHOPPAUL
Share this post
Link to post
becker 1
type 4462
cdr 220
ser# Y5052490
THANKS IN ADVANCE
PAWNSHOPPAUL
Try 5046
Share this post
Link to post
Hi, need code after disconnecting battery.
Traffic Pro
BE 4761
Ser# 15007291
Thanks in advance.
Nils
Should request the 5-digit code
Use 15126 ... :)
Share this post
Link to post
Traffic Pro
BE 4761
Ser# 15007291
Thanks in advance.
Nils
Use 15126 ... :)
Bruce2010 is correct Traffic Pro is a 5 digit code.
Share this post
Link to post
becker 1
type 4462
cdr 220
ser# Y5052490
THANKS IN ADVANCE
PAWNSHOPPAUL
Try 5046
thank you so much, it worked first try, you guys are the best people, i cant tahnk you enough, THANK YOU, Pawnshoppaul
Share this post
Link to post
I have a 2000 Boxster with a CR 220 radio/cassette. The battery was changed and I need the radio code. The serial number of the radio: CDC-3 Y1052323. Please help!! Thanks, Barbara[/size][/size][/size]
Share this post
Link to post
CDC-3 is CD Changer not the radio.
Please review the Lost Radio Code FAQhere
Share this post
Link to post
Got it! I got the following results: Type: 4462; Serial # &5042555. Then upon further turning the knob to the right: 24/99 and then CDW Reset. Hopefully this is all you need to help me find the 4-digit radio code! This is a 2000 Boxster, 5-speed manual transmission, Arctic Silver w Black interior, US, 6-cylinder engine, 2.5 liter displacement, Thanks! Barbara
Share this post
Link to post
Try 9150
Share this post
Link to post
Hi there - I have just bought a 2000 Boxster S and after battery disconnection the radio is off. Radio is CDR220. The model is 4462 and the serial number is X5032528
many thanks in advance
Share this post
Link to post
Try 8934
Share this post
Link to post
Try 8934
thank you very much - that did it !
Share this post
Link to post
Hi Loren,
Can you help ? Dealer wants $200 Canadian to help !
Type: 4462
Serial # 15001055 (NOTE: 1 might be an "i" or "L"
Cheers !
David
2002 996 C4S
Share this post
Link to post
Hi Loren,
Type: 4462
Cheers !
David
2002 996 C4S
Try 0250
Share this post
Link to post
  • Similar Content
    • By Steven Powell
      My CR-220 plays the FM & AM & Cassette, doesn't play the 6 Pack CDs. Faceplate does not display, all presets work, and equalizer.  Is the problem in the face plate or radio?  Will getting another faceplate work with this radio?  Will it change the radio code.
    • By Ig.ny
      “Thank you worked like a charm!!!! I have a foxwell, getting error codes 31 ignition circuit - side airbag , driver
      and 21 ignition circuit, driver
      no idea what to do. Horn works depending on its mood. “
      Please help
      Any suggestions  would help. I’ve taken off the door panels and disconnected and reconnected the airbags.
    • By Kevin Bryck
      2002 996
      Welcome everyone to another installment highlighting the wonderful world of fragile Porsche parts!
      Have both 17" and 18" wheels and have recently lost the metal Center Cap logo medallion off of one wheel of each size.
      While removing the other center caps every remaining medallion fell right off in my hand.
      Metal medallion secured with a random dab of some type of adhesive.
      We have reached the end of lifespan of whatever adhesive the Center Cap supplier used to keep precious colored metal medallions stuck to those cheap plastic caps.
      Anyone know how to remove old adhesive?
      Anyone have any idea what adhesive to replace it with?
      Anyone know how much the Porsche/Piech families made selling replacement center caps last year?
      Remember when paying through the nose for your precious replacement Center Caps that the Porsche and Piech families are the 7th wealthiest oligarchs in the world per Wikipedia.
    • By Loren
      Which radios fitted to Porsche can have their unlock code recovered through serial number?
      - CR-220/CDR-220 - Becker
      - CR-210/CDR-210 - Becker
      - Traffic Pro NAV/CD - Becker
      Which radios can not have their unlock code recovered through serial number?
      - CR1 - Alpine
      - CDR-23/24 (or later) - Becker
      - PCM (Porsche Communication Management) – Siemens & Becker
      How to get your radio serial number?
      CR-220/CDR-220:
      Hold down the TP button for at least 10 seconds after you turn the radio on. "Becker 1" will be displayed. Rotate the right knob (slowly) and it will display the Becker model number. Then rotate it again and the serial number should be displayed on the radio.
      Or, if the radio is out of the car the then the serial number is on the label.
      CR-210/CDR-210:
      Press tone, then 8 and 0 simultaneously. "Becker" appears. Press station up arrow on right. "PR-VERS" appears. Press one of the numbered buttons below the display, directly below the LCD arrowheads (try a few). The model number will appear. Press station up arrow on right. "SERIAL N" will appear. Press the numbered button again. The serial number will appear.
      CDR-23 (or later):
      These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected.
      Traffic Pro:
      Select the Service Menu, press NAV and multifunction key 10 simultaneously in radio mode. Use multifunction keys Nxt and Prv or turn the right control knob to select the individual items.
      You can move through the following items:
      - Model-No.
      - Serial-No. <-- this is what we need
      - Changer Reset
      - GAL
      - Radio Software
      - Radio Bolo
      - Navi Rom
      - Navi Flash
      - RTC Value
      To quit the service menu, press END.
      I get a WAIT on the display - what do I do?
      You have to wait at least 30 minutes before trying again.
      The suggested number did not work - what do I do now?
      Most often when the code we give you does not work it is because the serial number came from an old card in the car rather than from the procedure stated above - or a typo in the serial number submitted. Double check the serial number you submitted using the procedure above again.
      If that does not work then you will need to contact a dealer or Becker. Becker charges to look up your code and some dealers also charge.
      Our program works maybe 99.9% of the time but we have no explanation why it doesn't always work.
      Can you give me a code for my PCM?
      These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/ OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
      Sorry, the only place you can get a PCM code is from a dealer/ OPC.
      Can I post my VIN to get a code?
      We do NOT need your VIN - only your radio serial number.
      Where can I post my lost code request?
      Please post your request here:
      Please DO NOT PM me or email me (or anyone else helping with the codes) your radio code request - we will only answer requests in that one thread.
