pennyporsche
Got it! I got the following results: Type: 4462; Serial # &5042555. Then upon further turning the knob to the right: 24/99 and then CDW Reset. Hopefully this is all you need to help me find the 4-digit radio code! This is a 2000 Boxster, 5-speed manual transmission, Arctic Silver w Black interior, US, 6-cylinder engine, 2.5 liter displacement, Thanks! Barbara
I have a 2000 Boxster with a CR 220 radio/cassette. The battery was changed and I need the radio code. The serial number of the radio: CDC-3 Y1052323. Please help!! Thanks, Barbara[/size][/size][/size]
CDC-3 is CD Changer not the radio.
Please review the Lost Radio Code FAQhere
Try 9150
Thanks!! It worked!! Your help is very much appreciated! Barbara
Share this post
Link to post
I did the ignition switch repair last night on my 2002 911 Carrera. I then found out I didn't have the radio card in my owner's manuals. Any help would be greatly appreciated.
Becker 1
Type 4462
S/N: 25016601
24/99 ?
Thanks so much
Landon
Share this post
Link to post
Becker 1
Type 4462
S/N: 25016601
24/99 ?
Thanks so much
Landon
Try 9262
Share this post
Link to post
Hi Loren... looks like you're the radio code Queen :) would appreciate your help after changing batteries.
2001 Boxster 2.7 5-speed
Becker CR220
Type 4362
Serial Y5023005
Thanks much in advance...
Share this post
Link to post
Hi Loren... looks like you're the radio code Queen King :) would appreciate your help after changing batteries.
Becker CR220
Type 4362
Serial Y5023005
Note correction above...
Try 5071
Share this post
Link to post
Hi Loren,
Another sad soul looking for a radio code for the CDR-220.
Type 4462
Serial Number Y5035507
Thanks in advance
Share this post
Link to post
Becker CR220
Type 4362
Serial Y5023005
Try 5071
My sincerest apologies for that grave error and misguided assumption...
You da man... :)
Thanks so much, worked perfectly!!!
Share this post
Link to post
Hello, :notworthy: I'm locking for my code
CDR23
model # BE 6612
Serial # 35051136
Thank you for your time and info!
Your radio ..is not coded, in that it needs to have a code entered by the user. The radio is IMMO coded and will only work if connected to the original vehicle... :)
See FAQ:
Share this post
Link to post
CDR23
model # BE 6612
Serial # 35051136
Please read the Lost Radio Code FAQhere
The CDR-23 does not require a code (as stated in the FAQ).
Share this post
Link to post
Greetings,
Becker CDR-220
Type 4462
Ser# Y5043528
Thank you
Edited by Cicero
Share this post
Link to post
Hi, i just bought a 2005 996 Turbo S with Nav and I didn't get any radio code. Can I get a code for it?
PCM 3.0 ( PCM 2 OS 3)
System Software 3.0
Device Type 6632
Serial Number: 45047756
Edited by Sam996TTS
Share this post
Link to post
System Software 3.0
Device Type 6632
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/ OPC. The PCM’s require two codes, the ICS/Siemens code and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/ OPC."
Share this post
Link to post
I got three radio codes with my car... one in the manual, one noted on a repair invoice, and one written on the radio, and of course none of them work. Here is the data:
Becker CDR 220
BE4462
W5008917
Thanks very much,
Tom F.
Share this post
Link to post
Becker CDR 220
BE4462
W5008917
Thanks very much,
Tom F.
Try 3482
Share this post
Link to post
  • Similar Content
    • By Ig.ny
      “Thank you worked like a charm!!!! I have a foxwell, getting error codes 31 ignition circuit - side airbag , driver
      and 21 ignition circuit, driver
      no idea what to do. Horn works depending on its mood. “
      Please help
      Any suggestions  would help. I’ve taken off the door panels and disconnected and reconnected the airbags.
    • By Kevin Bryck
      2002 996
      Welcome everyone to another installment highlighting the wonderful world of fragile Porsche parts!
      Have both 17" and 18" wheels and have recently lost the metal Center Cap logo medallion off of one wheel of each size.
      While removing the other center caps every remaining medallion fell right off in my hand.
      Metal medallion secured with a random dab of some type of adhesive.
      We have reached the end of lifespan of whatever adhesive the Center Cap supplier used to keep precious colored metal medallions stuck to those cheap plastic caps.
      Anyone know how to remove old adhesive?
      Anyone have any idea what adhesive to replace it with?
      Anyone know how much the Porsche/Piech families made selling replacement center caps last year?
      Remember when paying through the nose for your precious replacement Center Caps that the Porsche and Piech families are the 7th wealthiest oligarchs in the world per Wikipedia.
    • By Loren
      Which radios fitted to Porsche can have their unlock code recovered through serial number?
      - CR-220/CDR-220 - Becker
      - CR-210/CDR-210 - Becker
      - Traffic Pro NAV/CD - Becker
      Which radios can not have their unlock code recovered through serial number?
      - CR1 - Alpine
      - CDR-23/24 (or later) - Becker
      - PCM (Porsche Communication Management) – Siemens & Becker
      How to get your radio serial number?
      CR-220/CDR-220:
      Hold down the TP button for at least 10 seconds after you turn the radio on. "Becker 1" will be displayed. Rotate the right knob (slowly) and it will display the Becker model number. Then rotate it again and the serial number should be displayed on the radio.
      Or, if the radio is out of the car the then the serial number is on the label.
      CR-210/CDR-210:
      Press tone, then 8 and 0 simultaneously. "Becker" appears. Press station up arrow on right. "PR-VERS" appears. Press one of the numbered buttons below the display, directly below the LCD arrowheads (try a few). The model number will appear. Press station up arrow on right. "SERIAL N" will appear. Press the numbered button again. The serial number will appear.
      CDR-23 (or later):
      These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected.
      Traffic Pro:
      Select the Service Menu, press NAV and multifunction key 10 simultaneously in radio mode. Use multifunction keys Nxt and Prv or turn the right control knob to select the individual items.
      You can move through the following items:
      - Model-No.
      - Serial-No. <-- this is what we need
      - Changer Reset
      - GAL
      - Radio Software
      - Radio Bolo
      - Navi Rom
      - Navi Flash
      - RTC Value
      To quit the service menu, press END.
      I get a WAIT on the display - what do I do?
      You have to wait at least 30 minutes before trying again.
      The suggested number did not work - what do I do now?
      Most often when the code we give you does not work it is because the serial number came from an old card in the car rather than from the procedure stated above - or a typo in the serial number submitted. Double check the serial number you submitted using the procedure above again.
      If that does not work then you will need to contact a dealer or Becker. Becker charges to look up your code and some dealers also charge.
      Our program works maybe 99.9% of the time but we have no explanation why it doesn't always work.
      These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/ OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
      Can I post my VIN to get a code?
      We do NOT need your VIN - only your radio serial number.
      Where can I post my lost code request?
      Please post your request here:
      Please DO NOT PM me or email me (or anyone else helping with the codes) your radio code request - we will only answer requests in that one thread.
